Old 08-01-2017, 10:43 AM   #1
ultimohero
ultimohero is an unknown quantity at this point
S13 reverse light question
Hey, I have a s13 with a sr20. I replaced my transmission recently because 2nd gear was gone. After replacing it, the reverse lights stayed on. I figured the switch was bad and I replaced it. When I hole the switch in my hand, I can turn the lights on and off. But when I put it in the trans and put it in reverse, nothing happens.
Since it worked perfectly before, what in the transmission operates the reverse light switch?
Thanks
ultimohero is offline   Reply With Quote
Old 08-01-2017, 11:20 PM   #2
Eoken
Eoken is an unknown quantity at this point
The only information i found was on "MT-5" of the service manual
http://www.240edge.com/manuals/s14_sr20det.pdf
sorry it is not really any help but maybe it will give you a lead. form where it is located it seems like it would be triggered by the shifter fork or something on the shifter fork shaft for 5th gear and reverse.
Eoken is offline   Reply With Quote
Old 08-01-2017, 11:52 PM   #3
ultimohero
Thanks I appreciate your answer. I think I'm gonna put it on a toggle switch until this one breaks too. Lol.
