![]() 1990 240sx hatch
first off I apologize for the terrible pictures. feel free to have me text you more pictures or information. location: Lake Oswego, Oregon contact info:541-690-6601 Asking price $13k OR BEST OFFER OR TRADE:I am open to trades, trades plus cash, or cash. mainly looking for a good daily driver for my wife things I'm interested in trading for WRX, EVO, CTS, 4 door luxury cars, 300c, I'm not interested in another 240, or motorcycles. feel free to offer up but please don't low ball me I am asking far less than what I feel the car is actually worth/what I have put into it. I'm sure there are a few other things I'm forgetting but the car is not far off from being super clean! I have been working on this car on and off for the last 4 years, however I no longer have time or energy for the car, and have decided to sell it. the motor has about 600 miles on a fresh build runs flawlessly I have been daily driving it around Portland. I spared no expense in building the engine. I will include all the left over painting supplies, 240sx parts and any other thing I feel should go with the car let me make this clear I do not NEED to sell the car I want to sell it! Exterior Fresh paint: color tuxedo black 350z wheels Oem Type x front bumper Jdm as fuck fiberglass front lip( unsure of brand but I've never seen another one like it) Oem type x slide skirts Oem type x rear valance (missing the center piece, not sure where it went) Circuit sports crystal clear front bumper running lights Brand new type x front turn signals Circuit sports crystal clear 180sx taillights New Nissan type x lower twilight garnish Pop up sun roof Nissan hood with uras fiberglass hood vent installed (small crack on one side) Locking carbon fiber "aero catch" style hood latches Breaks and suspension Z32 front calipers ( rebuilt by me 500 miles ago) Z32 rear calipers ( rebuilt by me 500 miles ago) Front and rear stainless steel braided brake lines (500 miles on them) Font and rear slotted and cross drilled rotors Ceramic break pads New s13 front lower control arms and bushings Abercrombie super steering knuckles New s14 inner tie rods New Abercrombie outer tie rod ends New front five lug conversion Z32 rear five lug conversion 180sx 5 bolt V-LSD (supposed to have stronger axles than 6 bolt) Fresh redline gear oil New rear upper adjustable control arm New adjustable rear reaction arm New adjustable rear toe arm Adjustable front tension rod Brand new powered by max competition coil overs (less than 100 miles on them) Wheels 350z wheels or will sell the Vienna's for a higher price SSR Vienna kreis Rear are 18x10, 3 inch lip Front are 18x8.5, 2 inch lip 2 inch bolt on spacers all the way around Engine (600 miles on full rebuild) RB25DET nissan skyline engine CP 8.5:1 Pistons Manly I-beam rods Balanced crank Tomei valve springs and retainers Fresh valve job on rebuild Cosworth 1.5 head gasket Oem intake gasket Oem exhaust gasket New oil pump New water pump New Nissan timing kit Raw Brokrage extended crank collar Arp head studs Arp main studs Arp rod bolts Acl rod bearings Acl main journal bearings Freddy intake manifold currently running rb25 throttle body Skyline gtr RB26 valve covers (why because I hate the look of the rb25 covers, and because I can) Mishimoto mini oil catch can, plumbed with black an fittings Raw Brokrage press in rb26 valve cover an fittings Wiring specialties engine harness With extra plug added for Z32 mass air flow sensor Will include z32 maf, q45 throttle body and blitz air filter R33 engine crossmember Transmission crossmember was extended to bolt in Transmission Stock rb25det transmission Stock clutch and fly wheel Fresh redline mt90 Driveshaft shop steel 1 piece drive shaft ECU The car is currently running on a stock rb25 ecu Engine bay Has a full tube front end Bash bars that fit the type x bumper Tubed front fender wells stitch welded Z32 rhd break master cylinder 180sx rhd break booster 180sx rhd clutch master cylinder Fuse box relocated to glove box and wiring harness tucked Fuel system Walbro 450 liter per hour fuel pump Aeromotive fuel pressure regulator and gauge New z32 fuel filter Cooling Koyo triple core rb/sr radiator Fresh fluids Dual Hayden 12" push pull electric fans 3" front mount intercooler with piping and couplers New cooling hoses and adapters New Raw Brokrage black silicone upper and lower radiator hoses Apexi old school blow off valve Interior Full interior Reclining Bride replica seat, on a slider rail Stock s13 passenger seat Driver and passenger takata 4 point cam lock harnesses(lost part of the harness in moving, lap belts are complete, shoulder straps need the metal part that bolts to the chassis. Can be easily made) Working r33 gauge cluster Auto meter electric oil pressure gauge Auto meter electric water temp gauge AEM wide band gauge, brand new Full right hand drive conversion Replaced the entire firewall and cowl panel Battery box Battery relocated to the hatch compartment Pioneer front and rear speakers Jvc head deck with aux and USB port Working heater No ac but all the rhd ac components are intact Cons takata harneses are not complete branded title small crack in windsheild crack in hood ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Oh good goodly moogly. There is so much work in this car! Absolutely beautiful. Good luck selling! I'd consider offering you a trade, but it's nothing you're looking for and we're too damn far apart.
Awesome build. Quick question if you don't mind but was the bras vent molded on to the factory hood?
Tags |
pbm, rb25, ssr, trade, z32 |
