Old 05-20-2008, 05:24 PM   #1
blacklable245
blacklable245's Avatar
blacklable245 is an unknown quantity at this point
Hard To Start SR20DET
Ok so this has been going on for awhile now just havent had the time to look deep into the problem, and before i started anything i wanted to get some ideas of what could be going on.
After letting the car sit for a couple of hours (2+) and try to start it up, it turns over a few times but it doesnt start till i smash on the gas a few times. Also, i have HORRIBLE mpg. I think it is due to a bad O2 from what i have been reading, if thats the case, anyone know where to get a sensor for SRs?
blacklable245 is offline   Reply With Quote
Old 05-20-2008, 07:31 PM   #2
Sileighty_85
Sileighty_85's Avatar
wow this is like the 5 thread about this
Check your ECU for codes, i can almost gaurentee your ECU will Flash a code 13
Which is your Coolant temp sensor
its either Unpluged or bad
$21 at autozone get it for either the KA or a 94 Sentra SER
the CTS is located above the Thermostat housing you will see two sensors the left one is the CTS when you remove it coolant will flow so be prepared to catch it.
Alfter installing and hooking up the sensor reset the ECU and all should be dandy
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
