Old 11-25-2017, 06:47 PM   #6691
Flicktitty
Flicktitty's Avatar
Does anyone know what rubber mounts TECH2 used to use on their JZ swap mounts? I pulled the engine today and noticed one has collapsed and would like to replace it but can't find any part numbers, it also looks a little different than a supra mount.
Old 11-30-2017, 03:58 PM   #6692
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
Originally Posted by Gar9854 View Post
Anyone else having an issue with vvti 1j's not bleeding the PS what so ever?
Stock return from the rack, ptfe AN high pressure. I've idled turned the wheel back and forth probably 50+ times with the car on jack stands (idling) and barely if any bubbles are appearing. Loosened the fitting on the pump and fluid drips quickly. Set the car back on the ground and the steering is still as hard as it was without fluid.
Sure you got the fittings going to the right places?
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 11-30-2017, 04:00 PM   #6693
Sky80
Sky80's Avatar
My friend with a rx7 has Supra mounts with his tech 2 kit. Any pics or measurement of the thickness from your other good one?
Old 12-28-2017, 07:12 AM   #6694
oscarsx
oscarsx's Avatar
oscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-known
Excuse my igronace never dealt with a swapped s-chassis.
In the middle of doing a 2jz on my s14, and I've also relocated the fusebox to the trunk. Now would I have trouble plugging in my specialty harness in or does not use any of the plugs on the fusebox itself? thanks guys.
IG: @ozc2jz
oscarsx is offline   Reply With Quote
Old 12-28-2017, 11:24 AM   #6695
e30gangsta
If anyone here is going 2jz I have a complete Collins adapter setup with everything for sale bnib. Everything you need minus the CD. If anyone is interested pm me.
Old 12-28-2017, 02:04 PM   #6696
Black240Ct
I believe there are two plugs on the lower harness that might need to be plugged in. I think its like a three wire plug and eight wire plug or something. they should be on the same sub-harness as the wiper plugs and larger black/ white plug with the lever (F4 I think).
its not a lot of wires if you need to extend them.
Old 12-28-2017, 02:20 PM   #6697
oscarsx
oscarsx's Avatar
That's perfect, thanks alot man!
Ig: @ozckouki
IG: @ozc2jz
Old 02-04-2018, 01:29 PM   #6698
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Ghost town in here. Just bought an S360 and a maverick adapter kit. Where’s everyone at?!
corkscrew is offline   Reply With Quote
Old 02-04-2018, 02:01 PM   #6699
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Figuring out how to pay for everything haha.
I'm about done(1j), cranks but no start, bad igniter and ecu.
di-devol is offline   Reply With Quote
Old 02-04-2018, 07:31 PM   #6700
corkscrew
corkscrew's Avatar
Ah that really sucks man. Hope it’s all good when you replace those parts
Old 02-05-2018, 07:14 AM   #6701
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Sold it all
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 02-05-2018, 10:13 AM   #6702
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
Post up how you like that S360. Are you 1J or 2J?
Local guy runs that turbo on a 1J and said its great.
I just picked up a cx racing manifold for cheap....might be going top mount soon myself. Also finally got an external oil cooler.
Have you tested your crank position sensor? ECU have power?
bmaddock is offline   Reply With Quote
Old 02-05-2018, 11:40 AM   #6703
di-devol
lol.
Ecu has power, fuel pump turns on, coils have power, injectors have power, crank, both cams, oil pressure, coolant temp, map and tps all checked out.
I hooked up my avcr to the ecu, so I was able to read the tps signal, so ecu had power, but no cel light, couldnt even get the light to turn on with a probe on w. Ecu had bad capacitors.
Igniter litterally fell apart.
Old 02-07-2018, 10:12 AM   #6704
corkscrew
corkscrew's Avatar
For sure man. It’s for my gf’s 2j vvti. My 1j vvti is all stock
Old 02-07-2018, 05:16 PM   #6705
Black240Ct
anyone have experience with ungraded injectors on a 1JZ vvti.
I ordered some ID 1050's (11mm for a 2jz)
and wondering if they will drop into a stock rail. Intake manifold.
Old 02-08-2018, 12:00 PM   #6706
Sky80
Sky80's Avatar
https://m.facebook.com/groups/160491737938096
Just created this group on Facebook, not sure if this is allowed but figured I’d share. Feel free to join in.
“240sx S Chassis 2JZ/1JZ Swap/For sale” group
Old 02-12-2018, 02:25 PM   #6707
di-devol
Got my stuff all sorted and running.
You guys know if the jz coolant temp is acurate on the stock cluster? In this case, 1jz->s13 coolant temp.
Old 02-12-2018, 03:37 PM   #6708
TheRealSy90
TheRealSy90's Avatar
I mean, even KA and SR sensors are different. Best bet would be replacing the temp sensor with whatever sensor matches your gauge cluster.
Such a good signature.
Old 02-12-2018, 05:11 PM   #6709
di-devol
Ok that works. I was just asking because I have the 1j one hooked up and it works, just didn't know if it was acurate.
Old 02-13-2018, 06:30 AM   #6710
jaysgottaredtop
jaysgottaredtop's Avatar
My 1JZ coolant temp sensor works on my stock S13 cluster. I also have an aftermarket temp gauge so I can monitor "actual" temps. The cluster temp needle seems to hop from one bar to the next at approximately the same "actual" temps as it did with my old SR setup.
Thus, I'd assume that the 1J CTS is pretty damn close to being scaled like an SR CTS.
At any rate, it's probably best to run an aftermarket 100F-250F gauge regardless.
Old 02-13-2018, 12:10 PM   #6711
di-devol
Im waiting for my gauges to show up :/
I just want to get it to running temp to check thermo opens, fans come on etc. Just dont want to overheat.
Old 02-16-2018, 12:27 PM   #6712
HypnoFish
HypnoFish is an unknown quantity at this point
I wouldnt trust the stock gauge. I used mine for along time and overheated once. luckily i had my laptop with me to view temps. The stock gauge was reading normal while my temps hit 270.
HypnoFish is offline   Reply With Quote
Old 02-20-2018, 12:00 AM   #6713
hoOzier
hoOzier is an unknown quantity at this point
Hey,
I am doing a similiar build but I'm having trouble finding a shifter, what transmission did you use? and how did you get the shifter to fit? I have a TR6060 similiar to a T56 and I'm not sure how to make things work
hoOzier is offline   Reply With Quote
Old 02-20-2018, 11:35 AM   #6714
di-devol
Originally Posted by hoOzier View Post
Hey,
This is the 2jz swap thread(kinda applies to 1jz as well), so there is a ton of info in here about it.
Some used the R154, some used CD009's with a serial9 shifter, collins shifter, some other shifter that took months to get(don''t remember the name).
I think there was someone asking questions about the TR6060 on here.
Old 02-22-2018, 06:55 PM   #6715
Sky80
Sky80's Avatar
Hey,
You have the tr6060 out of the Camaro then I assume? If you got one with the remote shifter, then you’ll need to fab that up and probably shorten it. If you didn’t, then you’ll need to get one and figure out the linkage.
Now, if you got a t56 magnum, then you would just simply need a ~3” shifter extension to get it dead center with the shifter hole.
Old 03-04-2018, 04:57 AM   #6716
corkscrew
corkscrew's Avatar
For everyone who’s gone single turbo, what are you guys doing for the oil cooler coolant line? I have the NA coolant pipe but I’m not entirely sure where to route hoses.
Old 03-04-2018, 09:37 AM   #6717
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Anyone have a reliable solution for power steering pump? My factory JZ pump leaks all over, and the aftermarket ones die too fast.
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 03-04-2018, 07:02 PM   #6718
di-devol
Driftmotion
https://www.driftmotion.com/Reman-7M...p-p/dm2456.htm
Old 03-08-2018, 09:33 AM   #6719
corkscrew
corkscrew's Avatar
Borg Warner S360 t4 .91
Where are you guys routing everything with the NA water pipe?
Old 03-11-2018, 09:50 AM   #6720
240sxrb30
240sxrb30 is an unknown quantity at this point
Has anyone figured out how to plumb the a/c?
240sxrb30 is offline   Reply With Quote
