Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 04-27-2009, 11:57 AM   #1
kaane21
kaane21 has a little shameless behavior in the past
z brake question
hey there everyone, i was wondering if anyone knew if brembo brakes from a 350z/G35 would fit onto 300zx hardware, or there was any kind of fabrication would be needed?
kaane21 is offline   Reply With Quote
Old 04-27-2009, 02:21 PM   #2
projectRDM
projectRDM's Avatar
Hardware? What in fuck are you trying to say?
Z33/V35 brakes bolt right up to a Z32 if you drill the spindle holes to 14mm. I don't know what kind of hardware you're talking about though.
FORMERLY R240NA
Old 01-21-2011, 06:56 PM   #3
VinceSpec
VinceSpec is an unknown quantity at this point
it does require just a little work, but pretty easy to accomplish. The carriers need to be drilled out to accept the larger hardware to bolt up to the brembo calipers.
VinceSpec is offline   Reply With Quote
