Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 02-06-2012, 10:33 AM   #61
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
Monday bump! Godspeed Project - Automotive - El Monte, CA | Facebook
Godspeed Project
2518 Continental Ave
El Monte CA 91733
P: 626-442-3988
W:godspeedproject.com
www.facebook.com/godspeedproject
Fatboy Garage is offline   Reply With Quote
Old 02-10-2012, 12:34 PM   #62
Fatboy Garage
TGIF! Bump!!!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 02-15-2012, 11:31 AM   #63
Fatboy Garage
Happy Hump Day!!!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 02-16-2012, 05:43 PM   #64
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
I don't really understand how these will help if you have to thread the outer on more... Care to explain? I'm looking for easy angle, but I wanna understand how it works first.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 02-16-2012, 08:25 PM   #65
TheRealSy90
TheRealSy90's Avatar
Gives more travel to the steering rack, more angle.
Such a good signature.
Old 02-16-2012, 09:14 PM   #66
EvoVIII808
Can take a look at the pics I posted. it might help you out a bit
Check Out My S13 Build
Old 02-22-2012, 10:21 AM   #67
Fatboy Garage
Happy Hump Day!
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 02-29-2012, 11:00 AM   #68
Fatboy Garage
Happy Hump Day!! Godspeed Project - Automotive - El Monte, CA | Facebook
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 03-05-2012, 11:14 AM   #69
Fatboy Garage
Monday bump! Like our page!!! Godspeed Project - Automotive - El Monte, CA | Facebook
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 03-07-2012, 11:43 AM   #70
Fatboy Garage
Happy Hump Day! Godspeed Project - Automotive - El Monte, CA | Facebook
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 03-13-2012, 11:01 AM   #71
Fatboy Garage
Happy Tuesday Bump! Check out our fan page!!! Godspeed Project - Automotive - El Monte, CA | Facebook
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 07-05-2012, 05:44 PM   #72
KABuddy129
KABuddy129 is an unknown quantity at this point
Do yall still have these in stock?
KABuddy129 is offline   Reply With Quote
Old 07-07-2012, 01:42 AM   #73
Johannes
Johannes's Avatar
Johannes is an unknown quantity at this point
Am I missing something here?
I just installed these today and re-centered my steering rack and adjusted my tie rods all the way but I still have toe in. I even adjusted the drivers side to have toe out all the way and just re-center it that way but I still had toe in =\
I also tried just installing these without the gold spacers but it still the same.
Johannes is offline   Reply With Quote
Old 07-07-2012, 05:58 AM   #74
TheRealSy90
Did you put one on each side of the rack? Without running longer control arms and modified knuckles you can only run one on the passenger side.
Old 07-07-2012, 10:01 PM   #75
Johannes
Johannes's Avatar
I'm only running one on the passenger side. I messed with it all day yesterday and today and still haven't figured out why it gives me so much toe in on the passenger side with maxed out tie rods.
Old 07-07-2012, 10:26 PM   #76
TheRealSy90
Hmm, I'm running one on the passenger side without the washer, and one powered by max washer on the drivers side. My tie rods are as short as possible and the toe is straight.
Old 07-13-2012, 05:15 PM   #77
demos_sav
demos_sav is an unknown quantity at this point
It's because you didn't center your rack after installing the spacers. That's why it gives you toe in only on one side
To center your rack:
1. Turn your steering wheel lock to lock and measure turns (e.g 3)
2. Divide by 2 and turn the steering wheel that amount of turns (e.g 1.5)
3. Align the wheels now so that they point straight
4(optional). If your steering wheel does not point straight then unbolt and reinstall it facing straight
You are done!!
demos_sav is offline   Reply With Quote
Old 07-15-2012, 02:29 AM   #78
TheZ31Guy
TheZ31Guy is an unknown quantity at this point
Do I PM you about buying this kit?
TheZ31Guy is offline   Reply With Quote
Old 07-30-2012, 06:29 AM   #79
MR_GUTTI
MR_GUTTI's Avatar
MR_GUTTI is an unknown quantity at this point
Do u still have this in stock? Let me know, thanks!
MR_GUTTI is offline   Reply With Quote
Old 08-15-2012, 05:00 PM   #80
Axel18
Axel18 is an unknown quantity at this point
Ummmm i have tein inner rods and outter ends, i tried the adapter but i had toe in and i maxed the rods in and i still had toe in, are the tein combo too long to use with the adapter?
Axel18 is offline   Reply With Quote
Old 08-15-2012, 07:46 PM   #81
TheRealSy90
I believe tein tie rods are longer than oem so that is why it's still toe'd in.
Old 08-16-2012, 11:07 AM   #82
Fatboy Garage
If you are using for instance s14 tie rods on a 13 then it might be too long. Let me know what your set up consist of !
Godspeed Project
El Monte CA 91733
P: 626-442-3988
Old 08-16-2012, 02:12 PM   #83
TheRealSy90
I'm guessing since the tein tie rods are designed with a built in tie rod spacer, it would essentially be like running a rack spacer on both sides on stock tie rods, which in combination with the Steering Angle Adapter the tie rods will be too long. I'm running one 7mm tie rod spacer on the drivers side, Steering Angle Adapter on the passenger side, stock tie rods adjusted full short, straight toe.
Old 11-06-2012, 02:31 PM   #84
artica
artica is an unknown quantity at this point
Just to make sure, the adapter and spacer go on the same side?
And is that Left side or right side.
Thought i would clarify since Passenger side could vary from U.S. to JDM.
Im currently having problems with mine.
I put spacer on left and adpater onright. But steering keeps pulling left after alignment and wheel rotation.
artica is offline   Reply With Quote
Old 11-07-2012, 12:39 AM   #85
EvoVIII808
NO, adaptor goes on passenger side, spacer goes on driver side. But 9 out of 10 if you run the spacer with the adaptor you will run out of threads on the tie rods to make your toe alignment straight (atleast i did). Your still toe in on one of the sides, recheck you alignment.. or you can remove the spacer from the driver side, realign and go from there.
Old 11-07-2012, 02:46 PM   #86
artica
Here's the exact situation.
I put 7mm spacer on left driverside and 12mm adapter on right passenger.
Recentered the rack and aligned the car. Also checked tire pressure.
Car drives straight until i let go of the wheel.
As soon as i let go, the wheel drops 1/4 to the left and pulls left.
Also when i pull into a parking spot with the wheel straight, as soon as i let go, the wheel drops
left 1/4 turn.
Where in the process might I be screwing it up?
P.S. replaced steering rack and it still pulls left
Old 11-07-2012, 06:18 PM   #87
TheRealSy90
Maybe your rack bushings are shot.
Old 11-07-2012, 09:24 PM   #88
artica
I have fresh new energy suspension bushings
Old 11-08-2012, 08:54 PM   #89
EvoVIII808
not 100% sure about this one, but it sounds like alignment to me. everything worked fine before you put the spacers in?
Old 11-10-2012, 02:39 PM   #90
artica
After re checking underneath the car and re examining the wheel width. It appears that my driver side is sticking out further due to an out of wack crossmember. Im going to see if i can readjust it and remeasure my adjustable flca's.
Maybe the driver side having more wheel width might cause a pull to that side.
Any input?
