Old 12-02-2010, 10:18 AM   #1
ov1989
ov1989's Avatar
Trader Rating: (31)
ov1989 will become famous soon enoughov1989 will become famous soon enoughov1989 will become famous soon enoughov1989 will become famous soon enough
Feedback Score: 31 reviews
s14 seatbelts on s13
So i put sum s14 seatbelts on my s13 n now i got the pillars that i have to make a hole thru to put the seatbelts the thru... if u guys got any ideas pls lmk THANKS ZILVIANS.
ov1989 is offline   Reply With Quote
Old 12-02-2010, 04:06 PM   #2
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
All the help you'll need is right here:
http://zilvia.net/f/search.php
You're welcome.
Irresistible is offline   Reply With Quote
Old 12-02-2010, 04:28 PM   #3
iHateMySilvia
iHateMySilvia's Avatar
Trader Rating: (30)
iHateMySilvia is an unknown quantity at this point
Feedback Score: 30 reviews
drill the hole and install?
NaVanBrosガレ​​ージLtd,Co.
iHateMySilvia is offline   Reply With Quote
Old 12-02-2010, 04:50 PM   #4
ov1989
ov1989's Avatar
Trader Rating: (31)
drill a hole?... i need a big enough hole to put seatbvelt thru tho...
Old 12-02-2010, 07:07 PM   #5
Tampa Drift
Tampa Drift is an unknown quantity at this point
The hole is basically so you can run your B pillar plastic, the hole for the seatbelt assembly to mount to is already provided....
Tampa Drift is offline   Reply With Quote
Old 12-04-2010, 01:28 AM   #6
TheEightyNine
TheEightyNine's Avatar
TheEightyNine is an unknown quantity at this point
Either get canadian pillars/headliner or make a big enough slit in your pillar to pass the actual seatbelt through. Ill be doing this soon, except ill be using b12 seatbelts.
To make the hole a hot blade, dremel or maybe a soldering iron will work. Havent made my mind up on which method ill be using
check this out
http://www.240sxforums.com/forums/934056-post15.html
TheEightyNine is offline   Reply With Quote
thanks zilvians.
