Old 01-15-2014, 03:18 PM   #1
KOUKI_VERS13
Trader Rating: (18)
KOUKI_VERS13 is an unknown quantity at this point
Feedback Score: 18 reviews
S13/KA/SR MISC. Parts
Payments by Paypal only, shipping is via USPS Flat Rate Box.
Help me get rid of all of this miscellaneous stuff.
Engine Stuff
-New 42 Draft Designs vacuum manifold kit, just missing the hose. $60
-New DEI T25/T28 turbo heat shield $150
-New OEM T25/T28 compressor inlet gasket $5
-New Sr injector seal set, upper and lower $15
-S13 SR heater hose assembly, coolant junction with temp sensor/gauge temp sensor $40
-New Greddy 3" silicone coupler $10
-New 3" to 2 1/2" reducer silicone coupler $10
-S13 SOHC ignition coil $20
-S14 KA Remanufactured MAF sensor $40
-S13 KA fuel injector seal set (upper/lower insulators and o-rings), like new. $5
-S13 SR alternator pulley $10
-S13 SR oil cap $5
-OEM S13 fuel filter, fairly new $5
-Earls 90 degree 1/4" ID hose barb to 1/8" NPT male. $10, includes two other fittings.
-New OEM S13 SOHC/DOHC KA oil filter (15208-55Y00) $5
-OEM S13 radiator cap, 1.2 bar $5
-New OEM S13 SR oil squirter. Mounts in block, below pistons. (11560-79F00) $15
-New SS braided -8AN line, 5' length $15
-Partial grey exhaust wrap, 1" x 10' $10
-Partial grey exhaust wrap with locking ties, 2" x 20' $25
Interior Stuff
-Lighted ignition cylinder with bezel and harness $20
-S13 SOHC tachometer $15
-S13 turn signal stalk $10
-S13 wiper stalk $10
-New Streetwires power distribution block (one ring terminal input, three 1/0 AWG outputs) $20
Exterior Stuff
-Pair of 5mm 4/5X114 wheel spacers $15
-S13 driver's side mirror $5
-(5) New OEM S13 front hub bolts (43222-35F00) $10
-OEM Nissan 12x1.25 lug nuts, standard length (3/4" socket, x16) $10
-12x1.50 RHT lug nuts, standard length (x16) $10
-12x1.25 lug nuts, standard length (15/16" socket, x12) $5
-12x1.25 lug nuts, short length (15/16" socket, x8) $5
Drivetrain
-HKS shift return spring set. Comes with new soft and inner springs as well as stock springs and plugs. Use the new inner and outer springs together to make medium stiffness shift returns. Hard springs not included. $40
-New OEM pilot bushing $5
-New ACT pilot bushing, for street/strip clutch kit $5
-Used OEM Nabco 5/8" clutch master cylinder $10
-New OEM needle wheel bearing for S13 KA or SR $10
Brakes
-Wilwood adhesive backed metal pad shims for their Superlite calipers, set of 4. $15 for the set
Misc.
-Bunch of stickers. $20 for all
-New Volk Racing wheel covers. They stretch quite a bit so it will work on various diameter wheels. $40
-Bunch of new OEM miscellaneous small parts. $15 for all
-New S13 aluminum solid steering coupler $40
-(1) 2 1/2" exhaust gasket, 2-bolt $5
-(1) 3" exhaust gasket, 2-bolt $10
KOUKI_VERS13 is offline   Reply With Quote
Old 02-17-2014, 08:37 PM   #2
KOUKI_VERS13
Trader Rating: (18)
Old 04-21-2014, 04:46 PM   #3
roxtaru
roxtaru is an unknown quantity at this point
Still have the oil squirters?
roxtaru is offline   Reply With Quote
Old 11-12-2014, 07:41 PM   #4
KOUKI_VERS13
Trader Rating: (18)
Updated......
Old 11-08-2015, 06:26 PM   #5
KOUKI_VERS13
Trader Rating: (18)
Stuff still available.
Old 05-20-2016, 09:57 PM   #6
KOUKI_VERS13
Trader Rating: (18)
..updated!
Old 05-21-2016, 01:33 AM   #7
jpy97gg
jpy97gg is an unknown quantity at this point
Hey Ill take the fuel filter !
jpy97gg is offline   Reply With Quote
Old 05-21-2016, 05:59 AM   #8
davin550
davin550 is an unknown quantity at this point
Pm sent. Interested in the turn signal and wiper stalks.
davin550 is offline   Reply With Quote
Old 08-02-2016, 10:55 PM   #9
KOUKI_VERS13
Trader Rating: (18)
Updated with more stuff!
Old 08-03-2016, 08:43 PM   #10
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
Price of the DEI T25/T28 turbo shield? I probably missed it...
1gr8bar10der is offline   Reply With Quote
Old 08-03-2016, 09:05 PM   #11
KOUKI_VERS13
Trader Rating: (18)
My bad, I forgot to post that one. Cheapest price I could find is $186. I can do $160 shipped, including PP fees.
Old 08-03-2016, 11:55 PM   #12
s14Irvin
s14Irvin is an unknown quantity at this point
Wiper switch ? Shipped how much ? And have the ka oem mounts by any chance ?
s14Irvin is offline   Reply With Quote
Old 08-06-2016, 11:10 PM   #13
KOUKI_VERS13
Trader Rating: (18)
Pm'd.
Whatever I have available is shown in the pictures.
Old 08-11-2016, 07:16 PM   #14
KOUKI_VERS13
Trader Rating: (18)
Old 08-15-2016, 04:56 PM   #15
KOUKI_VERS13
Trader Rating: (18)
Old 08-16-2016, 06:00 AM   #16
d_nice
d_nice's Avatar
good parts here. bump for the man
Old 08-19-2016, 09:00 PM   #17
KOUKI_VERS13
Trader Rating: (18)
Thanks.
Post updated.
Old 08-23-2016, 08:56 PM   #18
KOUKI_VERS13
Trader Rating: (18)
Old 08-29-2016, 05:06 PM   #19
KOUKI_VERS13
Trader Rating: (18)
Old 09-05-2016, 04:47 PM   #20
KOUKI_VERS13
Trader Rating: (18)
