Advertiser Announcements and Feedback This is where vendors can make announcements about upcoming promotions, events, items, etc. Vendors may also create threads here for the purpose of market research or other customer feedback. |
02-21-2015, 03:06 PM | #1 |
LS1 and LS2 Coil Pack harnesses - Now available!
LS1 and LS2 Coil Pack harnesses - Only $99 - ORDER HERE
The Wiring Specialties PRO SERIES LS1 & LS2 Coil Pack Harness is designed for a direct drop-in installation into any chassis utilizing the LS1 or LS2 engine. PRO-SERIES HARNESS INCLUDES • Brand NEW Construction • High Temp Nylon looming with adhesive shrink tubing • High Temp wire (280 degrees) • OEM connector specs (no cheap aftermarket connectors that fall apart) • Designed for a factory-like installation • OEM wiring connections and 'T' junctions. No soldered • Fully tested after production for an easy plug-and-play replacement • Turn Key ENGINE START Guarantee • Tech support for our customers 7 days a week.
Visit our Website - Check out our Blog - Like us on Facebook - Follow us on Instagram |
03-12-2015, 09:26 AM | #3 |
for what car platform?
04-10-2015, 09:41 AM | #5 | |
