03-04-2014, 11:15 PM | #1 |
SR20 running too lean to idle
My SR20det is showing really lean on my aem uego wide band and will not idle and cannot be held at a specific rpm, only feathering the throttle will keep it running. now if you introduce a 15sec spray of carb/brake clean to the MAF filter (z32 MAF) and then start it up, it idles and runs perfect and shows good readings on the wide band, and then after the carb/brake clean evaporates/gets used up, you can watch the a/f slowly go leaner and leaner. Ran the same test w/ known good ka24de MAF and got same results. (I have wiring specialties wire harness, came with several MAF pigtails) 99% sure timing is excelent. I know this sounds like a vacuum leak but does any one have any other ideas?
swapped red top s13 into s13 hatch new wire harness front mount intercooler gt28r turbo stock s13 sr injectors (yes i know these are not big enough for this turbo, only trying to get it to run and idle correctly) z32 MAF walbro 255 fuel pump (1 year old, was working great with the KA24de previously in the car) |
03-05-2014, 06:32 AM | #3 | |
Sent from my SCH-I535 using Tapatalk
'91 s13 (Drift Rocket Under Construction) 2000 civic Si Coupe (Daily) |
03-05-2014, 06:33 AM | #4 |
Never mind, just read you upgraded. My bad haha its coffee o'clock..
03-07-2014, 09:43 AM | #8 |
Trader Rating: (37)
Feedback Score: 37 reviews
I was going to mention that if your ECU is tuned for the z32 MAFS, putting the kae MAFS on will not give you better results.
Glad that you figured out the problem...hopefully.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple Last edited by kruked; 03-07-2014 at 10:15 AM.. |
