01-20-2010, 12:17 PM | #361 | |
well everything is behind the dash ducts and such which reminds me i have to remove mine to replace my heater core =( no heater for me as of now MAYBE SOMEONE CAN CHIME IN ON THIS TO HELP DIAGNOSE THIS! heres a pic behind the dash as you can see the climate contril there connected you can see whats going wrong and the FSM might help heres the link to a diy dash removal Technical Articles: s13 Dash Removal
**CoUpe LOve** #3 |
01-20-2010, 01:15 PM | #362 |
The alternator on my SR swap has a 4-rib pulley when it's supposed to be 5 so I'm guessing the previous owner used his old DOHC alternator and neglected to change the pulley? It works I guess but it squeals like a bitch all the time...
The belt looks like it's new still and the tension's set correctly. Could the fact that it's the wrong belt/pulley be the cause of the squealing? Anyone know the part # for the SR alternator pulley? |
01-20-2010, 01:46 PM | #363 |
I have a question alright I was wondering do any other 5 lug hubs from other cars like J30, 300zx ect fit into a s14 trying to save money
I know some frown being cheap but i cant help it lol |
01-20-2010, 03:11 PM | #364 |
I have two questions:
#1-Is an S14 ('95) already wired for fog lights even if your car doesnt have any? #2-Is an S14 ('95) already wired for a power antenna evin if your car doesnt have one? It looks like the plugs are already there for the fogs. You would just untape the plugs off the harness, plug your fogs in and replace the switch on the column with one with fog light controls on it. Anyone? The antenna thing im really unsure about. But i have a plug back there im unsure about. Was hopeing to run a power antenna on my car. Thanks for any help!! |
01-20-2010, 03:21 PM | #365 |
yes, you can use REAR Z-32 N/A rear hubs for 5 lug. For the front u can just get s14 5 lug. Buy them new at the dealer...IIRC they arent that expensive.
01-20-2010, 06:48 PM | #367 |
Anybody know if there is a US vehicle's Valve cover Rubber grommets (for the screws) i can use for the RB25 Valve cover?
I thought maybe the Z32 but theirs look alot thicker. I know The Nismo Shop has them but im not paying 3.00 EACH for them when i need 20 of them
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
01-21-2010, 12:55 AM | #370 | ||
more info is at 240sxtech.com look for 5spd maual swap if you're still unsure you can hopefully get one of the engineering tools from someone which i can't remember the name of but you can use it to check the dimensions (the one that looks like it has beaks) and just use a sharpee to pin point everything G.L.
**CoUpe LOve** #3 |
01-21-2010, 02:30 AM | #371 |
I rewired my zenki s14 for kouki headlights and now my headlights works fine but i don't know why but after that none of my other lights work(taillights, corners,etc).
I think its a fuse but haven't check bc the previous owner relocated the fuse box and haven't found it yet but anybody know why this happen? |
01-21-2010, 06:29 AM | #372 |
IIRC im pretty sure a 1 3/4 inch hole saw will work out. you need a right angle drill, or a small size air drill cause the space you have to work is pretty tight.
01-21-2010, 10:00 AM | #373 | |
.. . Anybody? |
01-21-2010, 11:18 AM | #374 |
Don't know the actual pitch, but S13 and S14 are the same. When I put an S13 SR in my S14 I reused the S14 temp sensor. Screwed right in.
01-21-2010, 11:20 AM | #375 |
I was able to do it on an S14 without any special drill. Just a hole saw. Took 2 minutes. I forget the size, you don't have to get it right on, you can make the hole slightly larger than the clutch master.
01-21-2010, 12:11 PM | #377 |
where to get big boy spacers that fit 5 lug nissans.
in talking about 38mm all i can find are ones with 1.5 threaded studs. |
01-21-2010, 12:36 PM | #378 |
Bandwagon.
hit up parts by max
01-21-2010, 10:08 PM | #380 | |
i just searched and found nothing. weird.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
01-21-2010, 11:24 PM | #382 |
on a s14 for 17x9.5 +15 (mb battles) will i need to pull the fender or just a roll
i want to run 235/40/r17
https://www.linkedin.com/in/hassanbakar |
01-22-2010, 02:19 AM | #384 | |
Bandwagon.
if your getting all four! yes! the set is 400+ or if you can find it cheaper. |
01-22-2010, 07:26 AM | #387 | |
I don't know if I can so so I will just put it here. It could be simple as a fuse, first thing to do is to check the fuses. If it is not popped, then check the wiring that leads to the cig lighter.
01-22-2010, 11:14 AM | #388 |
01-22-2010, 01:49 PM | #390 | |
If there is no panel in the car telling you which fuses are what, then your next option is to consult the Factory Service Manual
Tags |
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
