Old 01-20-2015, 04:26 AM   #31
laurentj23
laurentj23's Avatar
laurentj23 is an unknown quantity at this point
Blown ignition fuse. But it still wont fire up. I have to use obd2 reader and see whats going on.
Fuel pressure at 55
Sparks present on the plugs
Havent connected the maf yet but from reading around, it shldnt prevents it from not firing up. Ecu has been flashed , so i know that vats has been removed...
'Born Ready!',LJ
laurentj23 is offline   Reply With Quote
Old 01-20-2015, 02:10 PM   #32
nick Ritter
nick Ritter is an unknown quantity at this point
Fuel pressure at 55
it will fire without a maf but won't stay running or it will run like shit if it does
do you have HP tuners ? its a wise investment you can pick it up over on ls1 tech for $350 used
nick Ritter is offline   Reply With Quote
Old 01-20-2015, 03:22 PM   #33
laurentj23
laurentj23's Avatar
So maf sensor is not the issue? It wont even start at all. I dont think my crank sensor is bad.
'Born Ready!',LJ
Old 01-20-2015, 03:56 PM   #34
nick Ritter
I'm pretty sure if your crank sensor is bad the fuel pump will not turn on so if you have fuel pressure i don't think thats the case
the maf does matter unless the car is on speed density O2 sensors matter to
Old 01-20-2015, 05:47 PM   #35
laurentj23
laurentj23's Avatar
Ok. Im using 5 pin ls6 maf so i guess both iat and maf are not connected since 5 pin uses those.
'Born Ready!',LJ
Old 01-20-2015, 05:52 PM   #36
nick Ritter
i ment to say crank sensor isn't bad
if your running a ls6 maf on a ls1 pcm you need to calibrate it
you really should invest in HP tuners hands down best software I've ever used very easy to use also
you can also scan for codes and much much more it helped me a lot
Old 01-23-2015, 04:59 AM   #37
laurentj23
laurentj23's Avatar
Ok. Got the obd2 codes and it came out as map sensor low voltage. That map sensor is new. Cam sensor . Plugged the maf sensor. Which turned out that the pigtail they gave me is for ls3 6.2l . Thats after buying 3 mafs! Getting there
'Born Ready!',LJ
Old 01-23-2015, 08:48 AM   #38
nick Ritter
good work ! keep pluggin away !
