10-19-2012, 08:24 AM | #1 |
S14 ECCS relay wiring
Almost done with the wiring on the swap and for some reason this silly ECCS relay is messing with me. Can anyone confirm that this is correct? Pins 87 and 85 have a factory crimp a couple inches down from the relay and if my understanding is correct then 85 should be a ground even though it doesn't look like one. I would think that 86 would be the ground with 87 and 85 being the switched and acc.
Uploaded with ImageShack.us I'm not a wiring guy but trying to learn. This has been my source for wiring up the ECCS relay and will be for my coil relay. I've bounced it off a couple other sites and everything matches between the sites. FAQ: RELAYS; how they work and how to wire it up...
