Old 11-24-2010, 01:12 AM   #1
S13pign0se
S13pign0se's Avatar
S13pign0se is an unknown quantity at this point
s13 Ka24e cold start problem. HELP!
alright. so i have a 1990 s13. bone stock engine. only thing is i have a egr delete.
when the weather gets colder, prolly around 35-45 degrees when i start it, it will start up and begin shaking and bogging, sometimes it almost dies, once the temp needles starts to move up the shaking stops and it runs perfectly.
also: when the weather is warm, it starts perfect with no bogging or shaking at all.
any ideas of what it could be guys?
S13pign0se is offline   Reply With Quote
Old 11-24-2010, 07:04 PM   #2
240sohc
240sohc's Avatar
240sohc is an unknown quantity at this point
i have a similiar issue, i was told its the coolant temp sensor. im gonna buy one friday and install. ill keep you posted.
240sohc is offline   Reply With Quote
Old 11-27-2010, 09:57 PM   #3
240sohc
240sohc's Avatar
coolant temp sensor
i put a new coolant temp sensor in and it seems like it helped stabilize the idle at startup...car starts at 1600rpm then drops slowly to 1000 then settles at 800rpm now. Before at startup car would start at 1600rpm then drop sharply and bounce to 300-500rpm and shake the car like its gonna die, only on cold starts.
note: old coolant temp sensor which was probably the original, was very dirty and had a layer of gunk around whole sensor, maybe you can trying cleaning yours if you cant buy a new one.
Old 11-29-2010, 06:44 PM   #4
S13pign0se
S13pign0se's Avatar
hmmm.
alrighty thanks alot man. ill have to check that out and grab one tomorrow and hopefuly it works. thanks for the input.
Old 12-18-2010, 05:45 PM   #5
tommytwo40hands
tommytwo40hands is an unknown quantity at this point
Originally Posted by S13pign0se View Post
hmmm.
hey man just wondering if this helped your car?..i have the same year with egr delete also and my car started doing this when it got cold..
tommytwo40hands is offline   Reply With Quote
