02-14-2015, 07:41 PM | #332 |
Trader Rating: (48)
Feedback Score: 48 reviews
No, but a boat load of $$$ can...
Sick car, truly is. I hope you get your bang for buck out of it.
Do you suffer from vaginal dryness... |
02-17-2015, 09:50 AM | #334 | |
02-17-2015, 05:51 PM | #335 |
Trader Rating: (18)
Feedback Score: 18 reviews
Numbers coming soon. She isn't quite done being tuned and there will also be a video coming soon, as well.
https://instagram.com/eck_matthew/ |
02-18-2015, 05:46 PM | #340 |
Trader Rating: (129)
Feedback Score: 129 reviews
dyno vids or gtfo!!!! also see if you can grab some info like what your cams are degreed at and what rpm the solenoids kick in at!
02-20-2015, 07:54 AM | #341 |
Trader Rating: (18)
No video yet, since there were a couple issues on the dyno. The one tire was torn up and the aem coils weren't performing well after ~7000rpms, so the session was cut short. On the bright side, even with those issues, the car did make just over 600hp on 22lbs. The end goal is to run 30-35lbs and be up around the 700hp area. The coils will be getting changed out and a new tire will be getting placed on. The next dyno session wont be for awhile, though, since the car needs to be stripped down and sent out for paint...so it can be at Tuner Galleria in time. Tuning will take place after paint and once the few issues are delt with (2-3 weeks). Brndck, I'll try to get that info for you.
02-20-2015, 08:47 AM | #342 |
You're running E85 right?
My SR20VET |
02-20-2015, 10:23 AM | #346 |
What backside are you running? When did you see full boost? What is your dwell time and plug gap?
My SR20VET |
02-20-2015, 01:49 PM | #348 |
shit is WILD. are you going to continue using aem coils or switch to something else? arent aem coils basically just denso?
02-20-2015, 02:33 PM | #349 | |
I'd love to see what your graph looks like and what your cam switch over points are.
My SR20VET |
02-27-2015, 09:50 AM | #351 |
The motor is back out and the car is off to paint.
Performance Parts // Track Prep // Fabrication **Follow us on Instagram @TFWorks For all the latest TF★ news visit our blog!! |
02-27-2015, 02:42 PM | #352 |
The AEM smart coils are rebadged Mercury Marine IGN-1A coils... wayyy cheaper than the AEM rebadged coils as well. Kind of like how Haltech rebadges GM/Continentals Flex fuel sensor and charges 175 vs 60 lol
IG:@AAPARKAH #ThisIsTheWolf |
02-27-2015, 03:28 PM | #354 | |
Research the old Audo Quattro's. Audi sort of "mainstreamed" the design but if I were a betting man, I would think it was first tested in F1 or CanAm series cars. Taken off the interwebs: When Audi introduced the 20V motor. The car was homologated with a unique special cast intake manifold with a dual plenum. One drawback of using a single intake plenum is that after the charge air passes through the throttle body, the pressurized air isn't going to hit the runners going to the head equally. Runners closer to the front near the throttle body could very easily get more air than the cylinder furthest away. The Air velocity could play a factor in this as well. Its a very different concept when compared against a normally aspirated car where each cylinder's vacuum draws air into the cylinder so a vacuous single plenum with velocity stacks makes alot of sense. Also on a normally aspirated car, its very common to see individual throttle bodies for each cylinder to get maximum airflow with the least pressure resistance. So how does one actually design an intake manifold that allows or at least attempts to provide equal airflow to each cylinder? Well why would one even want to? If modern electronics allows a different fuel injector pulse to each cylinder, we could just adjust the fuel flow to compensate for the difference in airflow. We could do that, but does that actually give us the most efficient use of the engine's potential? Surely if one cylinder is drawing in 50 cfm of air and another is drawing in 40 cfm, the ideal thing is to get each cylinder to take 50 cfm of air. More air means more fuel and that means more power. So in a perfect engine each cylinder gets an equal amount of air. Having one cylinder running rich or lean from unequal airflow could lead to premature engine failure. So simply put. Dual plenum intake manifolds are turbocharged version of individual throttle bodies... ....Its also characterized by its large 2nd plenum which sits over the primary plenum underneath. The primary lower plenum with connects to the throttlebody is gradually tapered like a cone with a continuous single vent slot that allows gas to pass into the 2nd plenum. The 2nd plenum acts as a collector which then feeds the runners to the head. Pressure in the 2nd plenum is equallized since its not effected by gas velocity and inertia or the pressure variation from front to back of the 1st plenum. Since flow equals velocity times area. The reduction in flow which is released through the side slot is equal to the reduction in area of the plenum assuming velocity is constant. So a smooth conical taper with establish equal pressure and air distribution into the 2nd plenum. |
02-27-2015, 04:02 PM | #355 | |
HAHA, I literally just posted this same information but you beat me to it.
03-10-2015, 12:55 PM | #356 |
Trader Rating: (18)
She's back from paint and getting QUICKLY assembled at Touge Factory for Tuner Galleria in Chicago on Saturday. Hopefully I'll see some of you guys there!
03-10-2015, 01:00 PM | #357 |
Two words,
Thug Life. haha but seriously phenomenal job guys, -Juan
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected] Scott's Personal Website/Blog: http://www.scottandkerryann.com |
03-10-2015, 02:13 PM | #359 |
Can you guys explain more about the power steering setup you're using?
95' S14, Kouki front, KW V3, RPF1's, caged, built LS6, rebuilt t56... drives pretty good. |
