Old 05-31-2011, 03:16 AM   #1
Robb
Robb is an unknown quantity at this point
KA 5sp Swap Questions (more)
Making sure all my tracks are covered before I go and purchase everything.. If I purchase an engine set out of a manual S14 (so that's Engine, Trans, Flywheel, Clutch, and shifter), I will need only the following, correct?
m/t Driveshaft (front+rear sections)
m/t Crossmember
m/t Clutch master cylinder
m/t Clutch slave cylinder
m/t Clutch hardlines
m/t Clutch rubber line and damper line
Clutch pedal
m/t Brake pedal (or shave down auto)
I plan on doing a rebuild on the motor, then boost and 5sp swap at the same time. And speaking of clutch, realistically speaking, what have your experiences been with holding up under power? I ask because I have pins in my left ankle that has been keeping me away from manual, so I'd like to see what the stock clutch would realistically hold to.
This would be for an OBDII KA S14.
Robb is offline   Reply With Quote
Old 05-31-2011, 11:08 AM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
M/T flywheel bolts (new)
M/T bellhouse and starter bolts
M/T Pilot bushing
Old 05-31-2011, 01:47 PM   #3
Robb
The pilot bushing should be the sale, since the motor is coming out of a manual car, correct?
Old 06-01-2011, 06:21 PM   #4
Robb
bump on this
