Old 08-19-2003, 01:12 AM   #1
Krazy91
Krazy91 is on a distinguished road
SR S13 fuel pump not coming on
Ok ive had this problem ever since I put my sr in, I have a walbro 255 pump, its installed correctly and works when i turn the key to on it doesnt come on, I know the pump works cause I t'd another wire onto it before and it came on and pumped fuel but wouldnt stop. I need some help here it's the only thing left. oh yea also the fuse is fine every other thing everything works electrical on the car lights wipers car cranks over everything except the pump
oh and yes i searched for about and hour and a half before I posted this
oh yea its a 89 hatch with s13 sr
I love my 240sx!
Krazy91 is offline   Reply With Quote
Old 08-19-2003, 05:33 PM   #2
the3SecondJerk
the3SecondJerk is an unknown quantity at this point
Do you have the fuel pump relay wire hooked up? If not....solder the black/pink runner wire on the SR harness to the black/pink runner on the 240sx wire thats already installed in your car. That wire is a relay so it only runs for 3 seconds when power is switched on then when the ECU asks for it'll punp fuel. The 3 seconds at first is to prime the fuel lines.
Someone please varify....I am pretty sure its the black/ pink wire.
Dan
Drive it like you stole it.
the3SecondJerk is offline   Reply With Quote
Old 08-19-2003, 05:35 PM   #3
the3SecondJerk
Oh yeah..in case your wondering the wires are located between the battery and the chassis.
Old 08-19-2003, 10:06 PM   #4
Krazy91
yea they are hooked up. so what to check next, the fuse is good too. that wire must not be getting power, the only time ive got the pump to turn on is when I t'd a 12 volt inigtion wire onto the black/pink
I love my 240sx!
Old 12-28-2003, 02:35 PM   #5
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
where is the stock fuel pump relay on the S13?
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 12-28-2003, 03:31 PM   #6
DRFT
DRFT is making a name for him/her selfDRFT is making a name for him/her selfDRFT is making a name for him/her self
old thread revied... ....the fuel pump relay is in the fuse box on the passanger side of the engine bay.
ApexNetwork.Net
Sacramento & Norcal Forum
DRFT is offline   Reply With Quote
Old 12-28-2003, 03:52 PM   #7
twitchy
twitchy's Avatar
I hate to be a bother...but whats the label on it?? I found the fuse for the fuel pump but the only relay i can find which is close says "egi pump"
Old 12-28-2003, 08:08 PM   #8
sil_8t
sil_8t's Avatar
sil_8t is an unknown quantity at this point
Send a message via AIM to sil_8t
Plugs by Battery may be wired incorrectly, they plug in but won't work without rewiring. Pump should run for 3 seconds then stop if flywheel not moving.
from heavy throttle
sil_8t is offline   Reply With Quote
Old 12-29-2003, 01:12 AM   #9
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
i had this problem it was the fuse.....thats prolly what it is
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 09-22-2007, 05:24 PM   #10
240sxnoob
240sxnoob's Avatar
240sxnoob is on a distinguished road
what size fuse is needed for the
walbro 255 can any 1 tell me
240sxnoob is offline   Reply With Quote
