08-24-2010, 12:51 PM | #1 |
S14 SR20DET to 1997 S14 wiper wiring help!
I have 1997 s14 se with a early s14 sr20det engine swap, I am having a hard time doing the wiper motor wiring under the hood. Basically I could use some help with wiring colors from the harness to the wiper motor.
Wiper motor colors are Light green Blue Yellow Red Black Harness colors are Orange Black Light green with red tracer Light green with black tracer Light green I do have the variable speed intermit at which I believe I have placed correctly in the body plug next to the ecu. Last edited by Triperformance; 08-24-2010 at 01:07 PM.. Reason: Typos |
08-25-2010, 12:50 AM | #3 | |
I followed a few swap guides for my wiper wiring then followed the fsm and they still didn't work. Turns there was a break in the power wire for the wipers when they got switched on. Put the positive power for the wipers elsewhere and caused a bunch of other problems for my car. So I don't have wipers yet again, eventually I will have them fixed before it starts to rain again.
Wayne |
08-25-2010, 09:18 AM | #4 |
Do you mind linking the pin numbers from the wiper motor, I can use the fsm for the sr harness's. I basically removed my connectors because I couldnt find someone who had one for me to cut and wire in. Was that your trial and error for the power situation? I'm also using the SR wiper amp.
The KA and SR fsm use both the same wiring colors for the diagram meaning their the same wire colors. What I could use is either a picture of the back side of a wiper motor plug identifying the colors of the wires at their pin locations.......or someone who can tell me the pin numbers with the colors. Anything helps, the sooner the better because I need to get a job vs putting a lot of guessing into my wipers so I can make it there when it rains lol. Last edited by Triperformance; 08-25-2010 at 10:06 AM.. |
08-27-2010, 09:15 AM | #5 |
I'm still looking for information, I dont have connectors! If someone could please take a picture of their wiper motors wires in the back or simply tell me what pin is what color on the wiper motors. Much thanks.
08-27-2010, 03:47 PM | #6 |
shoot me a pm, I will do this for you tomorrow during the day with sunlight. The ground is the most important wire imo. If it's not grounded properly they wont work right or it won't ground through the amp like it's supposed to.
Wayne |
