Old 12-10-2013, 01:18 PM   #61
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
ARP is 80ft lbs with the moly lube, not 90.
My SR20VET
Old 12-11-2013, 11:35 AM   #62
Danger_Dorn
Danger_Dorn's Avatar
Danger_Dorn is an unknown quantity at this point
Crazy...Idk how I'm only pulling 176whp. I beat the piss out of it. I had to take it easy as I had a new comp. clutch. Also my compression is 135 so Idk what kind of power putting a smaller Hg on would yield. Thanks for your input
Danger_Dorn is offline   Reply With Quote
Old 12-11-2013, 11:36 AM   #63
Danger_Dorn
Lol that 90ft lbs was a typo I meant 80
Old 12-12-2013, 12:33 PM   #64
AJZax
AJZax is an unknown quantity at this point
on first start up after oil priming system, did you let it get to full operating temp and then dump oil and filter?
Also when you honed cylinders, did you clean the cylinder liners with a brush, soap and water? Did you clean the block oil galleys etc?
Wait with a thick head gasket you're going to drop compression and loose some power there haha. But it shouldn't be THAT much loss of power lol. Who did your tuning?
www.ajdrift.com
Mansfield, A - 145
AJZax is offline   Reply With Quote
Old 12-13-2013, 09:02 AM   #65
kouki_mobster
kouki_mobster is an unknown quantity at this point
run it stock and see what happens
kouki_mobster is offline   Reply With Quote
Old 01-29-2014, 05:41 PM   #66
Danger_Dorn
Re-torqued the head studs and found out my intake cam was off by 1 tooth advanced. We're snowed in here so I can't run it but I'll update when I can
Old 02-04-2014, 05:47 PM   #67
Danger_Dorn
So the power gain was night and day. It pulls much harder now and runs smoothe.
