Old 04-13-2008, 04:08 PM   #1
zerooath
98 Kouki Slicktop. Tip Dealer!
zerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to all
Send a message via AIM to zerooath
KA24DE Problem... Came from nowhere.
I was driving my car the other day..headed home. Well my oil light flashed on and has i was making the corner went off. Well im almost home and the miles per hour start dropping and at first i just thought maybe my foot was to relaxed so i gave it a lil gas and the mph still dropped. Then i heard some sort of scraping type bullshit from the engine bay..not to loud but definetly noticeable.
I turned onto my road and the car died. I get it home and try to turn the key and the motor acts like it wants to crank but just wont. I check the oil dipstick and it is almost bone dry. To my knowledge the car has no oil leaks anywhere.
Anybody have any idea? Should i just drain all the crappy oil out and replace with new oil and give it another shot or is there something seriously wrong with her?
Car is a 1997 s14..motor has given me absolutely no problems till this. It has about 130k miles on the motor. Its also an auto if that matters.
Thanks for any help.
zerooath is offline   Reply With Quote
Old 04-13-2008, 04:12 PM   #2
murda-c
murda-c's Avatar
When was the last time you changed or checked the oil before this?
sounds like you had a leak and let it run dry or you were burning oil very fast.
Old 04-13-2008, 04:28 PM   #3
Signum Temporis
Signum Temporis is a well-known jackass
Send a message via AIM to Signum Temporis
do u mean rpm or mph... either way your engine has no oil in it, so thats most likely the cause of ur problem
Signum Temporis is offline   Reply With Quote
Old 04-13-2008, 04:40 PM   #4
murda-c
murda-c's Avatar
If your engine was run dry enough to lose power and make scraping noises and now it won't start, you need to rebuild it.
Old 04-13-2008, 04:45 PM   #5
zerooath
well tomorrow im gonna drain the remaining oil and replace with some mobil 1 and hopefully the bitch will crank up.
Old 04-13-2008, 04:50 PM   #6
Signum Temporis
i agree with what murda-c said. if there was a scraping sound u probably need to rebuild it because bad noises from inside ur engine are usually correlated to damage.
it would be better to rebuild it just in case before u try to crank it up again, because if u crank it up and whatever was scraping isnt inspected/fixed ur gonna ruin ur engine completely if its not already
Old 04-14-2008, 06:54 AM   #7
zerooath
well im not exactly sure how to rebuild a motor...ive never done it before but i mean..it couldnt be to to hard.How do i go about doing that?Is there a way i can check the motor now before i take the chance of messing it up even more?
Old 04-14-2008, 07:00 AM   #8
murda-c
murda-c's Avatar
have you drained the oil yet?
check the oil for metal particles.
If it looks sorta like glitter paint, you're going to need some kind of rebuild.
Open the valve cover and check the cams out.
http://www.zeroyon.com/index/content/view/24/47/
get a factory service manual from there for torque specs and sequences if you want to take the cam caps off and look at those journals.
Old 04-14-2008, 11:42 AM   #9
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
i say take off the whole oil pan...
cuz if there chunky shit in there...u need a rebuild
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 04-15-2008, 07:00 AM   #10
zerooath
Aight im going to get started on all that today when i get out of school.I hope i dont find any metal shavings.....im gonna be pissed off.
Old 04-15-2008, 08:41 AM   #11
Blown240sx
Blown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymore
Id say your going to be pissed then. Motor is seized up if it wont even kick over.
Blown240sx is offline   Reply With Quote
Old 04-15-2008, 10:27 AM   #12
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
Your motor is FUCKED. NO ifs ands or butts.
haha. i said butt.
gotta240 is offline   Reply With Quote
Old 04-15-2008, 10:29 AM   #13
zerooath
Damn. What all would I need for a rebuild if it came down to it? And most importantly..where would I find all the things i would need? Parts store? Dealership?
Old 04-15-2008, 10:30 AM   #14
zerooath
haha damn you guys are negative as hell. oh well though..i would rather hear the truth then have it sugar coated
Old 04-15-2008, 10:35 AM   #15
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
Just for you, not sugar coated.
If you go to a stealership for a rebuild it will be around 2500-3000 plus labor. So 4k+
If your motor is reusable/doesn't have a ruined crank
If you can pull and reinstall the motor your self and put the head and timing stuff on........
Figure around $1000 For(timing kit, oil and water pumps, thermo, gasket sets, bearings other random things)
$500 the engine work(machine shop, assembly....)
If you damaged your cylinder walls add 3-400
Used KA
Under $500 plus the cost of fluids and what ever maintance you want to do to it before you put it in.
KA-T_240 is offline   Reply With Quote
Old 04-15-2008, 10:36 AM   #16
Blown240sx
Figure around $1000 For(timing kit, oil and water pumps, thermo, gasket set, bearings other random things)
You would be better off buying a used KA and swapping it in. You can find them for 300-600 dollars.
I am the Negative Rep Master
Old 04-15-2008, 10:40 AM   #17
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
try here http://www.importperformanceparts.net/. The prices are reasonable and shipping is fairly fast. The kits they offer come with all of the gaskets needed, bearings, and piston rings. They also have varying levels of their rebuild kit, which include pistons and rods, new timing components, oil pump, etc etc.
Honestly, rebuilding a motor is intimidating, but just take your time remember where things go, get a fsm, obviously and it's pretty much cake. If you dont feel comfortable a machine shop will do it, if you give them all of the parts for maybe 300$ or so.
one thing to learn about cars, always expect the worst cause if it comes out to be, you wont be as dissapointed.
louisdaboois is offline   Reply With Quote
Old 04-16-2008, 04:03 PM   #18
zerooath
Yea i think this bitch is pretty much toast. Im not even gonna try to rebuild it. No KA is worth getting into the thousands of dollars to have fixed imo.
Junkyard here I come
Old 04-16-2008, 06:41 PM   #19
verge513
verge513 is making a name for him/her selfverge513 is making a name for him/her self
aww man down dis ka's like that..there pretty well built engines i just rebuilt mine..if well taken care of and driven good they will last forever..and today with the gas prices knockin at 4 bucks a gallon..the ka's are decent on gas mileage or u could just slap in a eletric motor and 14 batteries and run forever
verge513 is offline   Reply With Quote
