Old 11-19-2013, 11:07 AM   #3121
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Oh and since my alternator died: what alternator are you guys running?
I'm about to go to the junkyard and find an LS400 to pull a 1uz alternator off of for cheap.
Anybody found a cheap high output alternator for the 2j?
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 11-19-2013, 05:12 PM   #3122
turbob16ef
turbob16ef's Avatar
turbob16ef is an unknown quantity at this point
There's someone on supraforums selling a 200amp for 100.
Nevermind on the alt, he sold it.
turbob16ef is offline   Reply With Quote
Old 11-19-2013, 05:22 PM   #3123
turbob16ef
turbob16ef's Avatar
Originally Posted by reynas14 View Post
I like the magnafuel 750 pump too but I heard that they sometimes arent reliable since they run hot and can burn the winding's! Have you used these before or know anyone that has? I don't want to run duel pumps but i will if its more reliable than a 500$$$ pump ya know lol
Also just FYI to anyone buying a drive shaft:
Shaftmasters is starting their black friday sales now and end on Dec 15th. They quoted me 340-342 shipped for aluminum!!! Thats a super good deal.
I need to try and find some measurements because i dont have a way to dry fit the engine and tranny until my buddies barns done this spring.........
Anyone on here have some good measurements?
My application is a 1996 240sx 2jzgte aristo R154 and my diff has a KAAZ 2 way if that matters. Thanks guys!
I haven't heard anyone have problems with the 750 pump. Most people don't wire them correctly, causing them to overheat or burn wiring/relays. The person I got my pump from had roughly 25k on it at 1100hp on e85. Said he never once had a problem. Which is another reason why people run the intank because they don't heat up the fuel. The magna750 is an awesome pump, use there dual relay setup, maybe even upgrade to 10ga wiring.
MagnaFuel MP-4303 in tank?
Old 11-19-2013, 08:14 PM   #3124
91ka24
91ka24's Avatar
91ka24 is an unknown quantity at this point
Could some one please look on there aristo 2j and tell me what color wires on the o2 sensor go to the harness color wires. The plugs are missing off my o2 sensor and my harness, so I need to splice em together
Follow me on Ig- Andydennington
91ka24 is offline   Reply With Quote
Old 11-20-2013, 09:02 AM   #3125
Black R
Black R's Avatar
Thanks for trying.
I'd prefer to buy something compatible at autozone, because they have a lifetime warranty and are everywhere + open 24hrs at some locations.
I'll research and see what I can find that has higher output and is cheap.
* so far, it looks like the aristo alternator puts out 65 amps and the LS 400 and GS 400 alternators put out 100 amps.
I've heard of them being interchangeable, so I guess I'll try and see.
Old 11-20-2013, 09:37 AM   #3126
Chronicle
Chronicle's Avatar
Chronicle is an unknown quantity at this point
Originally Posted by Black R View Post
Thanks for trying.
If they are, definitely let us know. I knew the Aristo alternators weren't great, but 65 amps is pretty terrible.
Daily: '99 Pontiac Trans Am. Projects: '96 S14, '87 Merkur XR4Ti
Chronicle is offline   Reply With Quote
Old 11-20-2013, 11:03 AM   #3127
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Damn and I was planning on running a system... guess Im going to need to upgrade
BiG MiKE86 is offline   Reply With Quote
Old 11-21-2013, 07:48 AM   #3128
Chronicle
Chronicle's Avatar
So I removed the exhaust manifold today and noticed that the exhaust port of the #3 cylinder on the head has a light coat of oil all around it. My mechanic friend told me that it's just a minor oil leak and ignore it. Am I just being paranoid about this?
Old 11-21-2013, 09:48 AM   #3129
BiG MiKE86
BiG MiKE86's Avatar
Alright guys... lets talk intercoolers...
Ive got a throwback Greddy V-SPL kit from my SR swap that I believe is only rated to about 300-350hp IIRC. Should I swap this out now before I get all my pipes fabbed or will it be ok? Im hoping to make 425-475rwhp right away
Old 11-21-2013, 09:55 AM   #3130
Chronicle
Chronicle's Avatar
What's the size of the intercooler's core, and what's the diameter of the piping? I'd compare whatever your specs are to some off-the-shelf 2J swap kits and see how they compare.
Old 11-21-2013, 10:42 AM   #3131
nsain
nsain is an unknown quantity at this point
oem toyota 130amp alternators for less than $100
130 amp OEM alternator for the JZ engines!
nsain is offline   Reply With Quote
Old 11-21-2013, 11:02 AM   #3132
Black R
Black R's Avatar
^ thanks.
Originally Posted by kane93tt View Post
The Tundra 03-04-05 V8 130A Alternator p/n is 27060-0F040
Application:
SEQUOIA 03-07 (4.7L, 2UZFE eng), 130 amp
TUNDRA 03-06 8 cyl, 130 amp
They pop for around 75-100$ shipped on eBay
Where are you guys tapping in the sending units for your gauges?
I have oil pressure, oil temp, and water temp...
The oil pressure one I'm using the Lexus long hollow banjo bolt.
The water temp one I'm putting in the lower rad hose.
But I'm stumped on the oil temp sending unit - should I put it in the oil pan?
Old 11-21-2013, 05:10 PM   #3133
boink
boink is an unknown quantity at this point
Hey guys,
Just finished my swap, and I've got some strange noise coming from the rear end ONLY when the car squats, so 1st-4th gear. Check the video, but if you cant - its a loud squeal, sounds like metal on metal.
Heres some info on the car.
1JZ with R154 S14 (stock twins)
3" exhaust with magnaflow muffler
Nismo 1.5 way diff
Full suspension arms
PBM subframe risers
Here are a couple things i have checked.
The wheel is not hitting the strut when it squats.
The driveshaft is not hitting the exhaust or ebrake clips.
Heres a video, let me know what you guys think, this noise is beyond me and its driving me nuts. I've never heard a diff make that noise, but maybe it is?
The noise persists until i let off.
https://www.youtube.com/watch?v=zkGBHg0pwCk
Appreciate any light you guys can shed.
boink is offline   Reply With Quote
Old 11-21-2013, 05:48 PM   #3134
Drink&Drift
Drink&Drift's Avatar
Drink&Drift is an unknown quantity at this point
Send a message via AIM to Drink&Drift
How low is your car? make sure your RUCA isnt rubbing the frame rail pinch weld above it, you have to notch that out if your car is low enough.
it doesn't sound like that is your problem, but worth checking.
sounds more internal in the differential casing, hate to say it.
Drink&Drift is offline   Reply With Quote
Old 11-21-2013, 06:01 PM   #3135
turbob16ef
turbob16ef's Avatar
I know you said you check wheel/strut. How bout wheel/lower control arm? Or possibly the U-joints?
Old 11-21-2013, 06:48 PM   #3136
boink
Car sits pretty low, wheel specs are 18x10.5 +15, about a half inch from tucking stock metal. I hammered the pinch weld pretty good, i would imagine that would be more of a bottoming out feeling.
I will have to check wheel to lower control arm, but i dont see any marks on the wheel.
Driveshaft is brand new.
Hopefully its not a diff issue, but at this point ill be happy to have the problem diagnosed.
Any other input guys?
Old 11-21-2013, 08:23 PM   #3137
AS240
AS240's Avatar
Trader Rating: (18)
AS240 is an unknown quantity at this point
Feedback Score: 18 reviews
You want the coolant temp sensor in the upper hose. You want readings of how hot the coolant is coming out of the motor, not how cool it is going in.
I've seen people use a "T" on the filter housing for oil temp and pressure. I'm sure in the pan will be fine as well, just make sure it's low enough so that it's always submerged in oil.
'92 HB HX35 rb25 - sold
'89 Coupe GTX35 VVT-I 2JZ - yeah buddy
AS240 is offline   Reply With Quote
Old 11-21-2013, 08:25 PM   #3138
AS240
AS240's Avatar
Trader Rating: (18)
^Exactly what I was going to say.
If you don't have your traction rods adjusted properly, the inner rim can rub the RLCA. Look for rubbing marks on both sides of the control arm.
Old 11-21-2013, 08:28 PM   #3139
turbob16ef
turbob16ef's Avatar
My wheels ended up self notching the control arms. Never heard any grinding. Only grinded when it was squatting, so couldn't hear it over everything else.
Old 11-22-2013, 12:39 AM   #3140
boink
Thanks fellas.
That might make sense, i just checked through my spokes and can see they are all the way in. (it did this before i did arms and rods, so i assume all the way in is = to stock?)
Tomorrow i will adjust them out and hopefully this fixes it.
Ill report back.
Cheers!
Old 11-22-2013, 01:13 AM   #3141
turbob16ef
turbob16ef's Avatar
You have adjustable lower control arms? If they are, more than likely tube. Shouldn't have any clearance issues with those I would think, but not sure bc I have stockers.
Old 11-22-2013, 01:16 AM   #3142
boink
No adjustable lower control arms.
Just traction rods that aren't set up correctly apparently.
Old 11-22-2013, 01:24 AM   #3143
turbob16ef
turbob16ef's Avatar
Ok, gotcha. 3am must be confusing me. Lol.
Old 11-22-2013, 02:43 PM   #3144
Black R
Black R's Avatar
Thanks, but isn't the water coming out of the motor always the same temp?
Old 11-22-2013, 02:47 PM   #3145
Chronicle
Chronicle's Avatar
Think about it this way. If the engine overheats, where is the coolant going to be at its hottest point? at the bottom of the radiator, where it enters the engine, or where the coolant leaves the engine? You want that sensor as close to the upper water neck as possible so you can detect a possible overheat as soon as you can.
Old 11-22-2013, 03:27 PM   #3146
Black R
Black R's Avatar
I was thinking more along the lines of monitoring whether the radiator is doing it's job.
And the fact that the factory dummy temp probe checks the hot water coming out of the motor.
That way I'm monitoring both locations.
Actually, maybe I'll probe both and compare.
Old 11-22-2013, 06:00 PM   #3147
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
^ thanks.
For oil pressure you could have used the port on the side of the block near the oil pressure/knock sensor. Its blocked by an allen key plug (forgot the term currently). It's used to determine oil pressure using a mechanical oil pressure unit.
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 11-22-2013, 07:30 PM   #3148
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
^ yeppp thats what I did! I used the drift motion steel braided line so I could mount my sender to a remote location.
Mr. Phonso is offline   Reply With Quote
Old 11-22-2013, 08:26 PM   #3149
Black R
Black R's Avatar
Got a pic?
Idk shit about these motors.
Old 11-22-2013, 08:50 PM   #3150
ATLspeed
ATLspeed's Avatar
Got a pic?
2JZGTE Block question - my.IS - Lexus IS Forum
95 Supra Turbo
