08-11-2009, 09:33 PM | #1 |
1989 white rebuilt SR fastback. JDM goodies 3100 firm
I'm now lowering the price of my car to 3100.
I need to sell it so i can purchase automotive tools. I'm selling for 3100 firm. This is a 1989 white 240sx 5 speed done at MotorX about 4 years ago. Since then it has been rebuilt and has about 4000 miles on it. It's Stock with the exception of Hks step 1 cams, Act stage 1 street strip clutch, 2 way lsd, apexi turbo timer, tien tie rods, XS Engineering intercooler, miata battery, HKS blow off valve version 2, sparco steering wheel and a few other goodies. The rear interior has been stripped and is covered by the stock hatch cargo bay cover. I have documentation for the rebuild done at steve shadow's friend's shop where he does his tuning. I have documentation for the machine work done. The head was fully redone to factory specs with "new everything". I used a 1.1mm apexi head gasket and the bottom end was built using ARP studs. I have other goodies on the side that i can provide such as gauges and a boost controller for an additional cost. I can also smog it for you for an additional cost. I'm looking for 3100 firm. no lowballers! Pretty much all sensors have been replaced. feel free to ask questions via pm or you can call/text me at 714-273-3406. I'm located in Garden Grove 92841. if you want to check it out let me know. I'm usually available after 4pm during the weekdays. Thanks. Need to sell asap!!!!
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
08-12-2009, 05:59 PM | #5 |
what kind of car do you have for trade? i'm looking for a daily unmolested civic haha.
08-12-2009, 08:37 PM | #7 |
sorry no salvage title. i'm looking for a clean, fuel efficient daily driver.
08-15-2009, 04:32 PM | #8 |
that sr looks wierd the head is smaller i think you got it from the junkyard huh glws tho
http://www.iwannagofast.net/ FOR SALE: DOHC maf, KA down pipe and SR A/C pump like new pm me for price. |
08-18-2009, 05:48 PM | #14 |
what suspension does it have
what 2 way is it does it leak over heat grind gears any exhaust leaks have the turbo gaskets been replaced clean title tags????
Violent Running Tribe if you haven't seen us youll hear us coming ! |
08-18-2009, 07:29 PM | #15 | |
not sure what 2 way it is. no leaks doesn't over heat doesn't grind gears no exhause leaks gaskets have been replaced has clean title needs smog. 3100 firm.
08-22-2009, 03:13 PM | #18 |
i'm now selling my car for 2700 but withouth the fmic and hks bov which i paid over 900 from XS engineering in Garden Grove. 2700 is now the selling price. you must provide the smic and i will install that for you. you'll need all the intercooler piping for the swap.
