Old 02-15-2013, 07:57 PM   #1561
RaNMaN
RaNMaN is an unknown quantity at this point
Originally Posted by RickS14 View Post
Good to know.thanks for the reply. Yea if I don't need a oil cooler I won't run one.
you do however need good and efficient water cooling. get a big good radiator and some high quality fans and don't worry about the oil cooler, keep it simple. good luck
RaNMaN is offline   Reply With Quote
Old 02-15-2013, 08:26 PM   #1562
RaNMaN
Originally Posted by PG BOOSTED View Post
Ok dude thank you.
Old 02-15-2013, 08:33 PM   #1563
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
What are you guys doing for the high pressure power steering line? Would be nice to know if the stock 240sx one will work.
Mr. Phonso is offline   Reply With Quote
Old 02-16-2013, 12:20 AM   #1564
PG BOOSTED
PG BOOSTED is an unknown quantity at this point
Originally Posted by RaNMaN View Post
Ok. Thank you. Can you explain your set up to me. you can post it here or PM me.
-Alex Bailey /18/ Orlando, FL / ⭐Founder of Straight Six Gang⭐
PG BOOSTED is offline   Reply With Quote
Old 02-16-2013, 08:31 AM   #1565
2muchboost
Trader Rating: (33)
Feedback Score: 33 reviews
@Ranman....more details plz. Also, I may be wrong but it doesnt look like you notched your rad support....am I wrong? What motor mounts and brackets? Thanx
Old 02-16-2013, 08:54 AM   #1566
PG BOOSTED
Originally Posted by 2muchboost View Post
@Ranman....more details plz. Also, I may be wrong but it doesnt look like you notched ou rad support....am I wrong? What motor mounts and brackets? Thanx
I noticed that too.
Old 02-16-2013, 09:37 AM   #1567
Mr. Phonso
Me three. He used a pusher fan instead.
Old 02-16-2013, 09:41 AM   #1568
RickS14
RickS14's Avatar
RickS14 is an unknown quantity at this point
I went with the chasebays radiator with fans.i was told that would be good enough..hopefully.
RickS14 is offline   Reply With Quote
Old 02-16-2013, 02:05 PM   #1569
Flicktitty
Flicktitty's Avatar
Question for you 1JZGTE VVTI fellas, Any idea if you can retain heat with the factory turbo setup?
Old 02-16-2013, 05:09 PM   #1570
Entranced
Entranced is an unknown quantity at this point
trying to decide which motor to go with... shooting for 650 whp with a big single on an AEM standalone. GE motor is $1000 less than an aristo GTE... is it worth getting the GTE or just stick to a NA-T style swap? My main concerns are intake manifold and ignition system... stock fuel will have to be upgraded either way.
I tried searching NA-T forums and such, but most of their responces are from people with the NA already who are only shooing at stock power levels ~450-500whp.
Entranced is offline   Reply With Quote
Old 02-16-2013, 05:33 PM   #1571
Entranced
probably not worth the troubles to go with a GE over the GTE anyways when starting from scratch... i want this thing running and seems like a quality intake manifold for the GE is around $500 anyways so i'm back at square 1 and then have to upgrade the ignition system anyways..
Old 02-16-2013, 07:20 PM   #1572
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
Switched out to a precision 6766, maxed the injectors out but made 652hp/538ftlbs on 28psi lol
2jz 240 dyno - YouTube
http://i98.photobucket.com/albums/l258/Deftec/signew-1.jpg
Deftec is offline   Reply With Quote
Old 02-16-2013, 07:36 PM   #1573
JohanM
JohanM's Avatar
JohanM is an unknown quantity at this point
What size injectors are you running?^^^^
JohanM is offline   Reply With Quote
Old 02-16-2013, 11:19 PM   #1574
PG BOOSTED
Has anyone brought any items/parts from PowerHouseRacing?
Old 02-16-2013, 11:27 PM   #1575
BoostedVR4
BoostedVR4's Avatar
BoostedVR4 is an unknown quantity at this point
Awesome. Seemed to spool very quickly also. I think this is the turbo I'd like to end up with. I ended up with a 6265 .86 to start with...
BoostedVR4 is offline   Reply With Quote
Old 02-16-2013, 11:59 PM   #1576
2jzs14
2jzs14 will become famous soon enough2jzs14 will become famous soon enough2jzs14 will become famous soon enough
It will work however it will have to be looped around in an ugly way to make it fit.
2jzs14 is offline   Reply With Quote
Old 02-17-2013, 07:24 AM   #1577
ta2dpnoy
ta2dpnoy is an unknown quantity at this point
yes you can. you can even use the stock s14 lower heater hose.
ta2dpnoy is offline   Reply With Quote
Old 02-17-2013, 10:07 AM   #1578
BoostedVR4
BoostedVR4's Avatar
@Boosted....I have a -10 line running to the front of the car then splitting (Y) into dual -8 lines into my FIC -8 Dual Feed Rail. Kept the stock return which is -6.
What kinda pump? I'm still trying to decide what I'm going to do. I want to re-use what I have. (Bosch 044, -8 feed, -6 return) Probably end up getting a 2nd 044, then either run another -8 up to a dual rail, or Y both pumps to single line. My cell has 2 outputs on the sump, so I can hook another pump up easily on the intake side. I know people still debate on single vs. dual feed rails.
Old 02-17-2013, 10:45 AM   #1579
2muchboost
Trader Rating: (33)
I had 2 044's but never installed them because of the size of the pumps and the terrible fuel tank config of our chassis. I would have loved to use them but it was looking more and more like the 044 use would have required me to run them off a surge tank and not twin in-tank. I have a friend who has them running twin in tank but he hasn't really tested the car out under spirited driving, only dyno use. I do love the 044's and think they are the best pump for the price.
Right now I have Ben Freeds old setup which is twin Aeromtive 340s in tank. This setup should be more than enough for my 700rwhp goal. Freed pushed this setup into the high 9s without any issues.
Dual feed rails have proven to work so I wouldn't think too much into it. There is a few local guys with 1000rwhp+ setups using a dual feed rails.
@Deftec.....very nice work. How do you like the turbo? I have the same with 1.0 ar and QSV. Any more info on your setup.
Old 02-17-2013, 10:58 AM   #1580
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
What do u guys do with all that junk under the intake manifold to the right?
BiG MiKE86 is offline   Reply With Quote
Old 02-17-2013, 11:12 AM   #1581
BoostedVR4
BoostedVR4's Avatar
What kinda fuel rails are you guys using? All I see is the cheap ebay stuff, and the insanely expensive stuff. Really nothing in between.
Old 02-17-2013, 11:14 AM   #1582
BiG MiKE86
BiG MiKE86's Avatar
Using fuel injector clinic -6 dual feed rail and FIC 770cc high impedance injectors
Reasonably prices quality stuff
Old 02-17-2013, 11:56 PM   #1583
turbo-2ns
turbo-2ns is an unknown quantity at this point
Yes they are local to me, good people have just about everything In stock. They have been around a loooooong time and are one of the most respected names in the supra,community
turbo-2ns is offline   Reply With Quote
Old 02-18-2013, 07:24 AM   #1584
BiG MiKE86
BiG MiKE86's Avatar
Anyone use Xcessive mounts with nismo mounts? Wondering if I have to grind off that lip on the top side to allow the engine to slide back/forth
Old 02-18-2013, 09:03 AM   #1585
Flicktitty
Flicktitty's Avatar
NICE! Should be fun!
I've been wondering what you have been up too!
AWESOME! Thanks much.
Originally Posted by BiG MiKE86 View Post
Attachment 50948
Thats a VSV pressure tank, if you're single turbo it can be removed.
Same.
Old 02-18-2013, 09:49 AM   #1586
PG BOOSTED
OK Thank You
Old 02-18-2013, 10:00 AM   #1587
BoostedVR4
BoostedVR4's Avatar
Thanks for the info. I already have a set of ID1000 injectors, I need to go get their measurements, then look for a rail. (they were mounted in a Supra, but never used)
I think I'm just going to run another -8 to a dual rail. I've already got one line run, and I'm pretty sure I have some -8 in the garage. I can always get fittings to work with a -6 rail...
Old 02-18-2013, 10:39 AM   #1588
BiG MiKE86
BiG MiKE86's Avatar
Any details on how to bypass/remove this stuff? Does the plug in the pic goto that vsv pressure tank?
Old 02-18-2013, 11:17 AM   #1589
Flicktitty
Flicktitty's Avatar
i just capped off the vacuum ports, yeah that plus is for a VSV.
Old 02-18-2013, 11:18 AM   #1590
BiG MiKE86
BiG MiKE86's Avatar
Did u Actually remove the unit or just cap off the ports?
