Old 08-20-2009, 10:09 AM   #1
chetacheese
chetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of light
Send a message via AIM to chetacheese
what is the difference between 91-94 ka and 95-98 ka?
sorry guys if i missed this somewhere but couldnt find anything about it. i want to know what the difference is between both engines and if theres any visual indication as to what differs them both.
chetacheese is offline   Reply With Quote
Old 08-21-2009, 01:51 PM   #2
projectRDM
projectRDM's Avatar
There's tons of info. You're not trying hard enough.
The easiest visual clue is the valve cover. S13 has three bolts down the middle, S14 has two. There's a dozen more. Search.
FORMERLY R240NA
Old 08-21-2009, 02:09 PM   #3
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
agreed...
another clue would be...temp sensor...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 08-21-2009, 02:10 PM   #4
miggsfiggs
miggsfiggs's Avatar
miggsfiggs is an unknown quantity at this point
they dont use the same driveshaft,and one uses or comes with an electric fan
miggsfiggs is offline   Reply With Quote
Old 08-21-2009, 03:09 PM   #5
projectRDM
projectRDM's Avatar
Please don't post when you don't know. Both cars use an electric fan. However, since the guy was asking about differences in the engine, chassis related parts have no bearing on his question anyway.
FORMERLY R240NA
Old 08-21-2009, 03:52 PM   #6
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Cams are different, CAS, gear ratios, clutch pedal -yes chassis I know, valve cover, IM, intake, Exhaust manifold (s14 has the cat in the downpipe, and a resonator in place where the S13 cat is)
Bigsyke is offline   Reply With Quote
Old 08-21-2009, 04:13 PM   #7
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
gear ratios? that's a big negative bro.
Old 08-21-2009, 05:15 PM   #8
projectRDM
projectRDM's Avatar
Indeed. So is the CAS, as the KA doesn't use a CAS, it uses a distributor. Cams are a change, but they're not visual.
So to kill this thread before even more stupid shit comes up:
valve cover
CTS
TPS
distributor
intake manifold
exhaust manifold
These are visual clues on the engine. That's what the kid asked for, quit with the parts that aren't even related. Sure you could say the seats are different too but that's pointless.
FORMERLY R240NA
Old 08-21-2009, 05:17 PM   #9
funes
funes is an unknown quantity at this point
another thing between the difference of those KA's:
the s13 have an extra spark plug wire from the coil to the distributor...
correct me if i am wrong...
EDIT: the s14 use a coil/distributor (2 in 1) or something like that so the s14 KA have only 4 spark plug wires and the s13 KA have 5 spark plug wires, also, the s13 have OBD1, 1995's s14's have OBD1 and 1996's to up have OBD2 ..
funes is offline   Reply With Quote
Old 08-21-2009, 05:24 PM   #10
[email protected]
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
right. s14 ka has a coil built into the distributer
or some shit like that
R@ddy is offline   Reply With Quote
Old 08-22-2009, 11:50 AM   #11
projectRDM
projectRDM's Avatar
That's why it's said the distributor is different.
To clear up your garble, The S13 KA uses an external ignition coil. S14 KA is internal.
FORMERLY R240NA
Old 08-22-2009, 12:06 PM   #12
Bigsyke
Bigsyke's Avatar
valve cover
CTS
TPS
distributor
intake manifold
exhaust manifold
Crank position sensor on the bellhousing? My s13 trans didnt have one, my S14 did. Yes its not needed, but none the less
I couldve sworn pulling both gear assemblies out of the bellhousings the 2nd gear on the s13 is shorter if I recall.
Old 08-22-2009, 02:38 PM   #13
funes
thanks for clear me mate
Old 08-22-2009, 03:10 PM   #14
projectRDM
projectRDM's Avatar
Fuck mang, you're killing us all. The OP asked about visual differences between engines. We could list every possible difference about every single part, true, but they're not answering the guy's question.
FORMERLY R240NA
Old 08-23-2009, 07:48 PM   #15
Clark W. Griswald
Clark W. Griswald's Avatar
Clark W. Griswald is an unknown quantity at this point
wow, gotta love the helpful attitudes and non elitist mentality among all the forum members. Really makes people want to contribute when you make them feel like shit for not knowing quite as much as you.
Clark W. Griswald is offline   Reply With Quote
Old 08-23-2009, 08:20 PM   #16
projectRDM
projectRDM's Avatar
If you asked me a question that you really needed answered, and I provided an incorrect answer, an answer not even remotely related to your question, wouldn't that bother you?
Case in point, this entire thread.
If it takes belittling someone or making them feel like shit for posting incorrect, useless, or unrelated information, so be it. Maybe they'll learn from it and stay on point next time.
FORMERLY R240NA
Old 08-24-2009, 04:07 PM   #17
chetacheese
thanks projectRDM. you actually answered my question in your first response. only looking for differences between the two ka motors appearance wise. not the technical side. thanks for all your help though. i tried searching but all the keywords that will reveal my interest wouldnt fit in the search bar.
