Old 03-30-2012, 09:13 PM   #1
Ewing
Ewing's Avatar
Ewing is an unknown quantity at this point
Front end pulsing vibration every 5 seconds?
I have noticed at speeds over 65 my front end starts shaking every 4 or 5 seconds and it lasts for maybe a second or two and continues until I slow back down. Any ideas what could cause this?
Ewing is offline   Reply With Quote
Old 03-31-2012, 01:38 AM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Try balancing your wheels and tires.
Old 04-01-2012, 09:56 AM   #3
TougeSR20Kid
TougeSR20Kid's Avatar
TougeSR20Kid has a little shameless behavior in the past
This, and an alignment couldn't hurt. I believe that incorrect castor can cause the wheels to vibrate like this
Originally Posted by mantas View Post
One more thing - i hate your prius.
Namaste mother f**ker
TougeSR20Kid is offline   Reply With Quote
Old 04-01-2012, 10:02 AM   #4
Nicelyphe
Nicelyphe's Avatar
Nicelyphe is an unknown quantity at this point
Mine does this as-well, was told it was my blown tension rod bushings =\
Nicelyphe is offline   Reply With Quote
Old 04-01-2012, 10:24 AM   #5
Ewing
Ewing's Avatar
I just had a full alignment. I'll get the tires balanced and see if that is what's causing it.
Thanks I'll give that a look.
Old 04-02-2012, 12:43 AM   #6
VinceDude
VinceDude's Avatar
VinceDude is an unknown quantity at this point
Sounds like a balance issue to me! Alignments like toe, camber, and caster would only effect tire wear and handling such as causing the car to pull or wander down the road. If you're experiencing vibrations it means your tires may need wheel weights.
VinceDude is offline   Reply With Quote
Old 04-02-2012, 08:46 AM   #7
Ewing
Ewing's Avatar
Balance is next on the list, thanks
