Old 05-02-2014, 12:58 PM   #1
jamg
jamg is an unknown quantity at this point
HKS wastegate adjustment with manual boost controller
What's the proper way to up boost to 17lbs via manual boost controller with the HKS internal wastegate?
At first i was only running 8lbs, which is stock.
now i've adjusted the rod, and I'm currently at 10lbs.
but I also have a manual boost controller hooked up, and i'm looking to reach 17lbs, but when adjusting the MBC, I'm not increasing or decreasing my boost.
is there anything else that i need to do to the HKS wastegate?
jamg is offline   Reply With Quote
Old 05-02-2014, 02:01 PM   #2
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
Sounds like you have the mbc hooked up wrong.
Why, may I ask are you using an mbc on top of the hks wastegate actuator (basically two MBCs)
Old 05-02-2014, 06:09 PM   #3
jamg
I might try out my friends MBC since I know his is good.
I followed the diagram for using a MBC on a internal wastegate.
What should the proper setup should be? If I don't run an actuator what should I use?
Old 05-02-2014, 10:55 PM   #4
hartig
hartig is an unknown quantity at this point
sounds like your mbc is hooked up backwards..
hartig is offline   Reply With Quote
Old 05-02-2014, 11:24 PM   #5
derass
The HKS actuators have an opening pressure of 0.8-0.9 kg/cm^2 (11.4-12.8 PSI). I would adjust the preload to get it into that range with the MBC disconnected. Then connect the MBC and adjust to get your desired 17 PSI.
http://www.hks-power.co.jp/en/produc...ch/product/197
Old 05-03-2014, 12:15 AM   #6
jamg
I'm thinking about extending the rod out. That way it stays open. And opens wider.
Old 05-03-2014, 12:41 AM   #7
brndck
brndck's Avatar
Clearly you don't understand how a wastegate works.
Old 05-03-2014, 09:37 AM   #8
hartig
sounds like everything is hooked up backwards..
Old 05-03-2014, 11:42 AM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You shouldnt't need a manual boost controller with the adjustable HKS internal wastegate. All you have to do is shorten/add more tension to the rod and it should raise the boost.
CLICK HERE!!!
Old 05-03-2014, 10:34 PM   #10
cratezhayao
cratezhayao is an unknown quantity at this point
cratezhayao is offline   Reply With Quote
Old 05-04-2014, 12:38 AM   #11
jamg
So if I want to run a MBC then what do I do with the HKS wastegate?
Old 05-04-2014, 01:22 AM   #12
Fuego
Fuego is an unknown quantity at this point
Set it to 1/2 or greater of your boost goal. Judging from your posts, maybe you should take it to a shop..
Fuego is offline   Reply With Quote
Old 05-04-2014, 08:27 PM   #13
TheRealSy90
TheRealSy90's Avatar
Definitely keep the wastegate open all the time that probably works.
Such a good signature.
Old 05-04-2014, 09:41 PM   #14
brndck
brndck's Avatar
Totally works. Every time.
Old 05-05-2014, 09:28 AM   #15
!Zar!
!Zar!'s Avatar
No.
Run the HKS wastegate.
MBC with a stock wastegate sucks compared to the HKS one.
Sell the MBC and move on.
You increase boost by shortening the rod on the wastegate.
And what turbo and injectors are you running for 17psi?
Also, what tune?
