Old 06-28-2012, 04:49 PM   #31
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
i like pittsburgh stuff, specifically this jack:
ive read that a lot of reasons the hoists go bad is because you have to add additional hydraulic fluid into them, as well as prime and bleed the system. and yeah hydraulics are known to drift so i can see leaving the load on with out a mechanical stop can affect things.
im also pretty set on getting their 4 leg stand
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 06-30-2012, 04:16 AM   #32
Dek-Thai
Dek-Thai is an unknown quantity at this point
^^^thats a nice jack
Dek-Thai is offline   Reply With Quote
Old 07-07-2012, 01:41 AM   #33
Drifting Kalamari
Drifting Kalamari is an unknown quantity at this point
I have never had a problem with my Harbor Freight Hoist!
Drifting Kalamari is offline   Reply With Quote
Old 07-07-2012, 11:55 AM   #34
NNOCENT
NNOCENT is an unknown quantity at this point
harborfreight 2ton foldable.
the space-savings was worth the extra money for me.
NNOCENT is offline   Reply With Quote
Old 07-07-2012, 12:25 PM   #35
ixfxi
ixfxi's Avatar
Originally Posted by hotboiblaze View Post
it isnt very technical, i agree. i do have experience with 'technical' lifts, and hoists. i have a category 3 crane license, i move multiple 4000 to 8000 pound high explosive missiles and torpedoes with 4 to 8 ton electric and pneumatic bridge crane daily. as well as operate 2 ton to 15k forklifts. and none of that is really difficult, but you still want to ensure youre using the right equipment for the job.
hey calm down, showoff
if you're such a hotshot, then why dont you use a category 3 crane to install your motor?
missles
explosives
torpedoes
and you drive a 240sx?
psssh
Old 07-07-2012, 01:06 PM   #36
dawagarage
dawagarage's Avatar
^ silly guy. it wasnt showing off. it might be showing off if i had said that in the first/first few posts, but not post 25. i said all that to show that im not technically inept, that i do have experience. 'hotshot' has nothing to do with anything. i wish i could use the cranes at work, then i wouldntve needed this thead. but alas, those cranes are all at work, installed on ibeams, and i dont have the option of having them in my garage nor could my garage support them.
the 3rd part i dont understand....
Old 07-07-2012, 10:10 PM   #37
ixfxi
ixfxi's Avatar
can i come to work and swap my motor?
LFA v10... should only take a few hours. brian, you in for the help?
brian harte world
Old 07-07-2012, 10:42 PM   #38
dawagarage
dawagarage's Avatar
you can try. you might be able to have someone get you on base but if you try to get down to the magazines or the compound, you might end up in prison.
Old 08-02-2012, 01:54 AM   #39
dawagarage
dawagarage's Avatar
called up harbor freight, they didnt have the 2 ton in stock. nor did any of the surrounding stores NOR the warehouse! online also says its unavailable.
anyways, im bumping this thread to let yall know of the great deal i found...
Pepboys has a 2 ton engine hoist available for $179.
similar if not exact design of HFs (im sure theyre all made in the same factory in china.) comparably, HFs is approx. 219. thats the cheapest youre gonna get
