Old 08-10-2009, 10:37 AM   #1
Kenji001
Kenji001 is making a name for him/her selfKenji001 is making a name for him/her selfKenji001 is making a name for him/her self
S13 Smog check help 2009
I have a 1993 S13 Hatchback with 257K miles.
My result:
Test 15MPH
HC: MAX 88 AVE 21 MEAS 113
CO(%): MAX 0.52 AVE 0.06 MEAS 0.35
NO(PPM): MAX 704 AVE 150 MEAS 929
Test 25MPH
HC: MAX 53 AVE 13 MEAS 63
CO(%): MAX 0.50 AVE 0.05 MEAS 0.18
NO(PPM): MAX 738 AVE 136 MEAS 322
I failed NO in 15mph test and HC in both 15mph & 25mph tests.
Here is my result from last year:
S13 Smog check help: KA24ET / KA24DET Forum: Nissan Forums / Infiniti Forums - NICOclub
What I did before the smog test:
1) oil change
2) Retard ignition timing to 15 BTDC.
3) With under a 1/4 of gas, I poured in 2 gallons of denatured alcohol.
When retarding timing, I tried to adjust the idle screw to 650 rpm with TPS sensor disconnected. However, I turned the idle screw to clockwise max. My digital timing light still says it is about 760rpm. The idle was rough and sometime stalled my car. So I turned counter-clockwise a little. The idle rpm is about 800 rpm. Then, I rotated my distributor counter-clockwise to retard my timing to about 15 BTDC. My idle was still fluctuate sometimes (500rpm then to about 700-800rpm for about 2 seconds).
Did I do this correctly? Please advise.
The EGR valve is working, but I didn't take it out and clean it. The cat looks like of old. I didn't do anything with the cat.
Reference:
1991-1994 240sx: Setting adjusting idle tutorial: Nissan Online Mechanic: Nissan Forums / Infiniti Forums - NICOclub
1991-1998 240sx: Timing Light Tutorial: 240SX Forum / 180SX Forum / Silvia Forum: Nissan Forums / Infiniti Forums - NICOclub
Kenji001 is offline   Reply With Quote
Old 08-10-2009, 11:31 AM   #2
Kenji001
I forgot to mention that I also failed:
Ignition timing: 15 BTDC
Fuel Cap Functional
For ignition timing, I adjusted it to 20 BTDC already. How about fuel cap functional? Do I just need to buy a new gas cap?
Thanks!
Old 08-10-2009, 12:30 PM   #3
fast-datsun
fast-datsun is an unknown quantity at this point
EGR bad or need cleaned , possable bad CAT, NEED NEW CAP IF THAT'S WHAT FAILED..
fast-datsun is offline   Reply With Quote
Old 08-10-2009, 01:15 PM   #4
blackrms13
blackrms13's Avatar
blackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfection
Send a message via AIM to blackrms13
oh yeah...forgot to mention..
even if u lift the valve on the EGR, and the engine dies out, that does not 100% mean the EGR is working....
then again ur numbers arent that far off...so i duno
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
