Old 08-06-2012, 10:02 AM   #1
Guilty1s
Guilty1s is an unknown quantity at this point
Simple z32 brake swap question
Do I need to have the z32 ebrake assembly to mount up the rear z32 calipers and rotors. Obviously i won't have an ebrake and know that the s14 isn't going to work. I know that. Just news to know if there isn't a space that the ebrake fills.. Ie shoes or offset spacing that will throw it off.
If no, is there a rotor that works without the ebrake hat.
Guilty1s is offline   Reply With Quote
Old 08-06-2012, 10:04 AM   #2
Edwin562
Edwin562's Avatar
Trader Rating: (35)
Feedback Score: 35 reviews
the question is, why would you not want to run the ebrake? just have some patients, save up some cash and get the ebrake assembly.
Old 08-06-2012, 10:11 AM   #3
7jpat
7jpat is an unknown quantity at this point
unless your doing a dual brake , but yeah what he said save up
7jpat is offline   Reply With Quote
Old 08-06-2012, 10:31 AM   #4
Guilty1s
Gonna run hydro and get a handle that has a lock. If I don't end up liking that, I'll pick up the dual caliper bracket and run with that which uses mustang rotors or something iirc.
Plus a friend of mine needs the ebrake assembly to put hers on her daily more then I need it for the drift car.
Old 08-06-2012, 11:21 AM   #5
DJ-of-E
DJ-of-E's Avatar
DJ-of-E is an unknown quantity at this point
Kudos to you.
I'm always afraid of the idea of running rear brakes without cable e-brakes in the rear. If your hydro fails, what can you do to top your car other than try to go off roading?
Originally Posted by ocn View Post
its not "DRIFT" tax its a "IDIOT" tax Period!
DJ-of-E is offline   Reply With Quote
