For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
05-21-2012, 08:48 AM | #1 |
FS: Enthalpy ECU, STI Injectors, SR Swap, Z Brakes, and a ton of other stuff!
I have way too much stuff in my garage so help me clean it out. Everything is obo for the most part, if you think my price is high or you're just broke make me an offer and we'll try to work something out. Everything is located in Zephyrhills. And I didn't feel like taking pictures of all this crap so if you need a picture of something just ask and I will get it for you, Text anytime 813 713 7946.
Full S13 SR Black Top swap SOLD Enthalpy ECU Dual Tune Board, It has two different chips in it so you can have two tunes stored on it, first tune is for stock motor, 550cc injectors, and Z32 MAF, second tune is for 740cc injectors, Z32 MAF and Cams. $300 STI 550cc injectors, comes with all the pigtails, drops right in an SR/KA fuel rail. SOLD Z32 MAF and Pigtail, has a hole in the screen after the MAF, won't effect anything though. SOLD Z32 1 1/16" Brake Master Cylinder, Still needs the third fitting pressed in. $80 Z32 26mm Aluminum Calipers, Good condition, Currently taken apart, $100 or $140 fully rebuilt S13 SR to S13 chassis Engine harness $130 S13 SR coolant temp sensors sub harness $20 S13 KA Dual Cam Engine harnesses, 2 mint and a few cut up ones that are good for wiring and plugs. $60 for a mint one and $15 for a cut one S13 5spd lower harness. $25 S13 Mint uncracked black Defroster Vents. $25 S13 SR Redtop Valve cover, pretty good condition overall no major scratches. $40 S13 & S14 KA valve covers, Nothing special, Something for you to paint. $10 each S13 & S14 5 lug front and rear Drilled and Slotted rotors, used but good condition. $30 for a pair or $50 for the whole set Ichiba 5 lug rear hubs, Bad bearings and 1 missing stud. SOLD S13 SR Black Top O2 Sensor. $25 S13 Power window amp. $20 Freddy type RS BOV. $20 SR Stock Turbo manifold & Stock Elbow. $25 for both S13 SR fuel rail, no injectors, has FPR. SOLD S13 T25 Factory oil and water lines. $10 each or $20 for the full set S13 rear calipers. $10 each KA Fuel rails with injectors and FPR, 1 s13 1 s14 and 1 from something else with a KA. $15 each S13 KA intake tube with good MAF. $20 S14 Distributor. SOLD SR Transmission Bell housing so you can use a KA Transmission. $40 S14 KA Exhaust Manifold. $10 KA Starter. $20 S13 KA AC Bracket. $15 S13 Rear mudflaps. $30 for the set KA Flywheel with bolts, needs a resurface. SOLD All this stuff here is $5 or free with any purchase over $25 KA Power steering bracket KA/SR Clutch Fork S14 Power steering reservoir S13 6 bolt axles S13 wiper motor S13 Driver side rear upright S14 air bag clock spring S13 single cam throttle cable T25 intake elbow KA water pump pulley SR water pump pulley S13 ignition key ring lights S13 fuses(the big 75 amp and smaller brown and green fuses) OBX White face manual oil pressure gauge Last edited by Seen; 05-26-2012 at 09:33 PM.. |
05-23-2012, 11:44 AM | #6 | |
Trader Rating: (35)
Feedback Score: 35 reviews
http://zilvia.net/f/wheels-tires/109...means-you.html |
