Old 06-27-2012, 08:04 PM   #31
bb4_96
bb4_96 is an unknown quantity at this point
im always surprised at the amount of shoddy wiring there is out there.
bb4_96 is offline   Reply With Quote
Old 06-27-2012, 08:09 PM   #32
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
right??? when i did the ka-t harness and the sr harness on my coupe, i soldered and heat shrank EVERYTHING. when i had to convert my obd 1 car to obd 2 - i heat shrunk and soldered all 60+ wires. its a lot of work, but it needs to be done to have piece of mind and to also not have a freakin fire! i wish people would understand that. this means that now im going to have to go thru all of the wiring and fix all of it. i already fixed some, but now im going to have to hunt down ALL of it.
AsleepAltima is offline   Reply With Quote
Old 06-28-2012, 11:40 AM   #33
Bentleyness
Bentleyness is an unknown quantity at this point
no one said timing. it should be @ 15* this fixed both my friends sr, the screw wasnt tight on the dizzy so over time it advanced to 25*
Bentleyness is offline   Reply With Quote
Old 06-28-2012, 12:07 PM   #34
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Originally Posted by AsleepAltima View Post
anyone what the "12mm" thing is for?
It's mentioning your are using the skinny O2 sensor for feedback, I asked the same thing lol.
I had the same problem, but it was the injector wiring. Good luck!
di-devol is offline   Reply With Quote
Old 06-28-2012, 01:13 PM   #35
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
Does sound like ignition related. LS Coils definitely would be a great upgrade. But personally fixing the wiring and adding a 30amp relay for the coils to get its power source direct from the battery may have helped.
Similar to this config that Yashio sells.
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 06-30-2012, 11:51 PM   #36
AsleepAltima
thats a good looking harness. i might do something like that to clean the bay up a little. im going to check my injector wiring too while im at it. i havent gotten my coils yet, but when i get them, im going to take my time and wire everything up real nice.
Old 06-30-2012, 11:57 PM   #37
hartig
hartig is an unknown quantity at this point
knock sensor? mine acted terribly for a while too, disabled the knock sensor, and it runs perfectly
hartig is offline   Reply With Quote
Old 07-01-2012, 12:15 PM   #38
AsleepAltima
id be nervous about disabling something like that on a turbo'd engine.
Old 07-01-2012, 08:35 PM   #39
AsleepAltima
question - im reading that some people wire in their uego's to send a signal to the ecu and eliminate the stock o2 sensor... can we do that with the sr20 ecu? i went thru the instructions for my aem uego and it has an output but im not sure the ecu can read from it since its looking for a narrow signal.
Old 07-01-2012, 09:05 PM   #40
spartanmisfit
spartanmisfit's Avatar
Trader Rating: (18)
spartanmisfit is an unknown quantity at this point
Feedback Score: 18 reviews
Do you have the problem only under boost?
spartanmisfit is offline   Reply With Quote
Old 07-01-2012, 09:28 PM   #41
AsleepAltima
only wot. i can boost semi-aggressively all the way to redline but it will sputter here and there if its wot or too aggressive.
Old 07-02-2012, 04:44 AM   #42
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Most wide band O2s have a narrow band output to be wired into the factory ECU if you wanted.
My SR20VET
Old 07-02-2012, 06:33 AM   #43
budderigs
budderigs is an unknown quantity at this point
it sure sounds like your on the right track. in between running alot of boost on stock coils. not to mention a possible electrical issue. a stutter and miss is going to happen.
food for thought, if the new ls coils dont solve the issue.
on my setup, lets say I have my car tuned to run at 15psi. then I decide I want to turn it up to 25 psi. as soon as it builds boost over 15psi it will run super rich and wll miss badly.
it does this because the higher boost setting draws more air through the maf.
i am sure your case will be a little differnt sense you have a rom bur and I am using a piggy back. but a maf controled engine is a maf controled engine. if that ecu is rom burned to run at 15 psi with turbo of (x cfm) and you are running higher psi or turbo with higher cfm flow. it is going to run richer. and once it runs to rich it is going to miss.
if the ls coils dont fix the issue I would suggest dynoing the car with a wideband on it. or install the wideband you have and watching what it does.
I would suggest getting a vehicle specific tune for your car no matter what.
budderigs is offline   Reply With Quote
Old 07-02-2012, 07:03 AM   #44
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
i made this for my sr20det..but i used heavier wire and i used a relay per 2 coils...^^^^^^^^^this sells for like 100..something ....
it cost me like 15 worth of materials...and i made it tougher then this
this is a relay for a chinese fog light
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 07-02-2012, 09:54 AM   #45
AsleepAltima
yeah a modified tune is definitely in the works. funny thing though, the last time this car ran was about 2009 or so, it ran at 20-22 lbs boost and didnt have this problem. when i got back from deployment and started putting this car back together, late last year, i went from the stock pistons to the 87mm pistons and 264 cams. thats the only major change in the setup. maybe the added flow is causing it? not sure. i kept the compression the same, so hopefully its not that and this car only sees 93 octane. i installed the wideband yesterday and just need to get the bung welded in now. the coils came in today so i gotta get those mounted and wired in now too.
on to the wideband... i was reading the instructions and i know which wire is the 0-5v output (not like its hard to find. lol) and was wondering, can i just wire that into the ecu harness now? using pin 19? will the ecu (jwt burned) see that signal and use it? just need to make sure so i dont get the bung welded in if i really dont need to.
you guys are a great help - hard to get help from zilvia sometimes and the nissan forums i moderate are not very sr20det heavy so not much help there.
Old 07-02-2012, 10:27 AM   #46
jr_ss
Trader Rating: (34)
Yes, you can run it to that pin. However tge ECU still sees it as a narrow band reading so you cant rely on it to tune.
My SR20VET
Old 07-02-2012, 10:38 AM   #47
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Yes you can run this, the AEM should have a simulated narrowband output.
Also, Knock sensor is useless above 4k rpm for SR, if yours is damaged/missing it will cause issues. BYPASS IT and be done. There are many write ups on how to do it. And I personally bypassed my own.
Check back after fixed.
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 07-02-2012, 10:41 AM   #48
AsleepAltima
understood. cody ace pointed me in the direction i need for logging thru the port. im not trying to tune with the narrow band, i just need it to keep sending my ecu the required signal. at least now, i dont have to get that bung welded in. i really really didnt want to pull the downpipe. lol
Old 07-02-2012, 10:43 AM   #49
AsleepAltima
you know, i painted my block after i had it bored out, acid cleaned and checked. i was careful to clean the area the knock sensor mounts to but it could still be a problem area now... ill try disconnecting it and see what happens - before i do the coil packs.
Old 07-02-2012, 10:46 AM   #50
AsleepAltima
i kinda answered my own question too... the 0-5v IS a narrow band signal... right? lol
Old 07-02-2012, 12:24 PM   #51
cotbu
cotbu's Avatar
No! it's not!
Old 07-02-2012, 03:53 PM   #52
AsleepAltima
Originally Posted by cotbu View Post
No! it's not!
cant just say no, its not - gotta say why it isnt...
Old 07-02-2012, 04:47 PM   #53
cotbu
cotbu's Avatar
it should have been obvious! The wide band signal is 0-5v.
Narrow band
Wide band
Old 07-02-2012, 08:23 PM   #54
AsleepAltima
got it.
figured it out - last question for the output wire is - which setting on the back of the gauge should it be set to? both p3 and p4 are 0-1v outputs, but i need to know if its autronic or nernst?
Old 07-10-2012, 07:07 PM   #55
AsleepAltima
car is fixed. dont know if anyone is even reading this, but the lsx/truck coils fixed the stuttering and the wideband revealed a new problem. power was there but at 5k rpm, it would go lean. i checked fuel pump voltage and it was low. jumped it from the battery and the problem is absolutely, completely gone. car now, in boost, is at 11.2-12.2 on the wideband and it pulls like a pissed off raped ape. also, the setting for the ecu to read the narrow band signal from the aem wb gauge white wire is p4. i removed the jumper and am putting together a relayed circuit that i will install in the morning. definitely a learning experience but im very pleased with my sr for the time being.
Old 07-10-2012, 09:56 PM   #56
ANDY black s13
ANDY black s13 is an unknown quantity at this point
Some good info there on both the coils and the pump feed,And glad you sorted the problem
ANDY black s13 is offline   Reply With Quote
Old 07-11-2012, 09:31 AM   #57
jr_ss
Trader Rating: (34)
Generally speaking, if you have a boosted motor and an upgraded pump you need to do the fuel pump wiring upgrade. Use the factory wiring as your relay 12v switch and wire the rest with larger gauge wire and directly from a battery. That way you no longer have psi drop under heavy load.
My SR20VET
Old 07-11-2012, 09:33 AM   #58
AsleepAltima
yeah i didnt expect there to be a problem because it wasnt there pre-build. i wired up a spdt relay last night and will install that today. it was definitely what the car needed. lol
