Old 08-22-2013, 08:30 PM   #1
kleng
kleng is an unknown quantity at this point
ka24de rev hangs at 1.5k
at idle itll stay at 700-1k, but once i gas the car itll rise up normaly the when it drops back down itll hang at 1.5k for like 1-3 sec. ive clean the iacv alfready, ive check the maf, the car has been egr deleted before i bought it. Would that be the cause to the rev hang. Car also has brand new clutch master 6 puck(installed by previous owner). i doubt the clutch would be the cause of the rev hang because it even hangs when revving the car while its in neutral.
kleng is offline   Reply With Quote
Old 08-22-2013, 08:35 PM   #2
Rich260z
Rich260z is an unknown quantity at this point
Possibly an auto ecu. Was it 5 speed swapped? because my auto to 5 speed swap does that.
Rich260z is offline   Reply With Quote
Old 08-22-2013, 08:45 PM   #3
kleng
Yes it was an auto swap. i will have to check the ecu.
Old 08-22-2013, 08:46 PM   #4
kleng
How will I know it's an auto ecu?
Old 08-22-2013, 09:15 PM   #5
Thedriftbadger
Thedriftbadger is an unknown quantity at this point
Mine does that too except it's more around 1300. Original 5 speed car
Thedriftbadger is offline   Reply With Quote
Old 08-23-2013, 06:01 AM   #6
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Most ka that have been EGR deleted, the RPMs sit around 1300.
Take a picture of the ECU and post it here. W/ the female socket facing you, I want a picture of the bottom, right corner. I'll be able to tell you if it's auto or manual.
I like my bikes how I like my b¡tches...naked!
2014 Triumph Street Triple
kruked is offline   Reply With Quote
Old 08-23-2013, 09:16 AM   #7
SkittlesA7X
SkittlesA7X is an unknown quantity at this point
Mine does the same kind of thing but in between 1.1k and 2k rpms it jumps. It will slow down normally and then act like I'm giving it a bit of gas and hang for a bit and then it will start to slow down again. Its factory 5 speed but ecu might have been switched out. It doesn't always do it though. Sometimes it runs perfectly fine. I have no idea what it could be. I went over all of my vacuum lines and I found a lot of leaks in my EGR system but I replaced them all.
SkittlesA7X is offline   Reply With Quote
Old 08-23-2013, 09:21 AM   #8
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
Mine doesn't, and I've never heard of EGR removal affecting idle if properly sealed. Why would it affect idle?
Frank_Jaeger is offline   Reply With Quote
Old 09-03-2013, 09:46 PM   #9
Tristan Barton
Tristan Barton is an unknown quantity at this point
Mine does the same thing, it's a auto to manual swap as well and it pauses at like 1500rpm exactly.
Tristan Barton is offline   Reply With Quote
Old 09-04-2013, 03:21 AM   #10
Ayy_mo
Ayy_mo is an unknown quantity at this point
Auto ecu sounds like the problem.
Originally Posted by Broadfield
What I want to know is what your hand is on the other .0001% of the time
Ayy_mo is offline   Reply With Quote
