12-17-2008, 09:53 AM | #1 |
clutch slave cylinder
soo i need to install my clutch slave cylinder but the clutch pedal has been pushed so its compressed
anyone know how to decompress so i can get the clucth slave back in?? |
12-17-2008, 09:58 AM | #2 |
Ive always just been able to push the rod back in with out a problem
if it wont then just open the bleeder valve on the slave and push it back in
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
12-17-2008, 10:01 AM | #3 |
I don't understand a word of what you just said other than you have to replace your clutch slave cylinder. If you mean that it failed in an extended position, just bleed the line and remove the bolts. I've never seen one fail in that position, so I assume you mean the pedal is pushed in and doesn't return to it's normal position by itself. Pull the pedal out, it will stay where it's supposed to.
12-17-2008, 11:46 AM | #4 | |
Tags |
clutch, clutch slave cylinder |
