Old 06-28-2012, 02:25 PM   #1
socalbmxr06
socalbmxr06 is an unknown quantity at this point
SR sr20 smoking out pcv valve
The motor is very fresh and professionally installed. Recently blew my turbo seals and noticed the dipstick even shot out some oil as well. Sent the turbo back to tomei and got a new one. Did a leakdown test and had high 90% across the board except cylinder 1 which was at mide 80% but according to the matco tester we used that was still excellent. Haven't done a compression test yet, but it should be good since the leakdown test was good.
The problem:
There is a large amount of smoke entering into the intake from the pcv valve t shaped vent. The actual pcv in the valve cover seems to work properly( too it off to check it out). There is no smoke out exhuast except the usual black smoke under full throttle. Also the car idles rough now.
Question:
What does this sound like to you guys? Please help. I will do a compression test soon as well. Do you think that it could be as simple as the oil is shot and I need new spark plugs???
socalbmxr06 is offline   Reply With Quote
Old 06-28-2012, 06:11 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Pop the line that comes off the crank case and see if you're getting smoke out of there. Also, if you have a pulse coming out of there, you got something going on with the bottom end.
CLICK HERE!!!
Old 07-04-2012, 09:44 PM   #3
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
Sound like too much crank case presure to me.Rings no beuno or something routed wrong creating crank case pressure......
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
