Old 08-19-2008, 01:44 AM   #1
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
high idle AHHH!
i start my car (ka24de) and right away its starts to rev high. got new spark plugs, changed the oil, seafoamed, and cleaned the MAF. still revs at 3-4000 rpms while its in park. in D its higher and wants to go.
does anyone have im going to clean the iacv tomorrow see if that helps. some times it idles high like that then sometimes it dosent.
like somthing is sticking?
repda916 is offline   Reply With Quote
Old 08-19-2008, 01:48 AM   #2
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
Check your idle screw on your throttle body, you probably lost the locking nut on it. Same thing happened to me on my ka, I would start it up and it would idle at 5k lol. Just adjust it and you will be good.
projekt_s13 is offline   Reply With Quote
Old 08-19-2008, 02:33 AM   #3
Sileighty_85
Sileighty_85's Avatar
make sure your throttle body cable is not caught on anything holding it open
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-19-2008, 10:07 AM   #4
drftthatshit
drftthatshit is on a distinguished road
also check the tps sensor it might be bad
drftthatshit is offline   Reply With Quote
Old 08-19-2008, 10:09 AM   #5
repda916
how do i check that? start the motor and unplug it?
Old 08-19-2008, 10:17 AM   #6
Okinawandrifter87
Okinawandrifter87's Avatar
Yup once you unplug it then adjust the idle to 800. Then plug it back in. Once plugged in it should adjust back to normal but if not then the tps is bad or needs cleaning. But im not sure how to clean it though. I need to find out how to replace or clean mine cause I have the high idle on my coupe right now as well. Any further advice anyone on replacing or cleaning?
Driftphreak87
Old 08-19-2008, 10:21 AM   #7
drftthatshit
the tps sensor can not be cleaned once you take the screws off and take it out of the throttle body you will see what im talking about all the tps is is an lever that moves up and down to tell the ecu that there is more air comming in to the engine really what i would do is just go down to your nissan dealer and pic up a new one there really not that exspensive and easy to replace
Old 08-19-2008, 10:24 AM   #8
drftthatshit
also check the iacv it might have gone bad this will be under the intake up against the firewall you can pull it out and clean it this might help trust me try cleaning first cuz the iacv is not a cheap part its about 200 bucks trust me. Try all that and let me know haow all this wrks out for you
Old 08-19-2008, 07:43 PM   #9
repda916
ok i think i found the problem. the idle screw is all the way in and it idles fine.
sometimes when i give it gas it will get stuck if i put my foot under the gas pedal and pull it towards me it will drop idle. so throttle body is sticking im guessing?
Old 08-19-2008, 08:14 PM   #10
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
dont guess, take the 2 minutes to pull off your intake and check.
aNskY is offline   Reply With Quote
Old 08-20-2008, 04:31 PM   #11
drftthatshit
clean the throttle body with some cleaner like you can use.......BG, Whynns, or some from pepboys ect. just pull the throttle body off and spend an hour cleaning
Old 08-20-2008, 05:38 PM   #12
jspeedm
jspeedm's Avatar
Trader Rating: (26)
jspeedm is on the path to ruinjspeedm is on the path to ruin
Feedback Score: 26 reviews
make sure your throttle cable isn't going over the side of the tb pulley if it does it sometimes and not others wait till it does it again and look at the pulley if the cable is over the edge it will hold the throttle open.
jspeedm is offline   Reply With Quote
