For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
05-13-2014, 10:28 AM | #1 |
Trader Rating: (115)
Feedback Score: 115 reviews
Parts Added 5-13-14 SR, S13 and S14 parts!
Located in Petaluma CA. Updated the list 5-21-14 (415) 724-0675 ENGINE PARTS SR Red Top Thermostat Housing - $10 SR20 Flywheel Bolts - $20 S13 KA24DE Fan - $20 S13 KA24DE Air Box - $20 SR20 Redtop IACV - $65 ACT 6 puck sprung hub clutch/heavy pressure plate (new clutch disk, pressure plate in good condition, 1 season) - $300 Megan Racing Short Shifter - $60 SR20 O2 Sensor - $35 SR20 Coil Packs - $100 SR20 Coil Pack Harness - $75 SR20 Redtop Valve Cover, powder coated white - $75 SR20 Redtop throttle body with TPS - $50 Z32 Maf Pigtail - $15 SR20 maf adapter with filter - $40 SR20 Redtop Alternator Bracket - $60 Greddy Blow Off Valve - $150 SR Oil Filter Relocation and Oil Pressure Sensor - $150 DRIVETRAIN S13 Rear Subframe (local only) - $80 S13 4 Lug Hubs (rear only) - $35 per pair SUSPENSION Pairs of 5x114.3 10mm slip on spacers - $25 S13 Driver Side Tension Rod Bracket (have 2) - $30 S14 Stock knuckles - $50 I have most stock suspension so let me know what you need BRAKES 2 Brembo Blank Z32 rear rotors (good condition) - $40 Carbotech race Z32 rear brake pads - $30 SS Z32 Rear Conversion Lines - $35 INTERIOR S13 Cluster Surround - $35 S13 Steering Wheel Adapter (nardi pattern) - $20 S13 Rear View Mirror - $15 S13 Center Console - $30 S13 Clean Dash - $150 S14 Glove Box, grey or black - $40 S14 Confetti rear seats - $50 S14 Cluster Surround - $35 S14 Center Console - $50 S14 Interior Mirror - $20 S14 Steering Column Switches (blinkers, windshield wipers etc.) - $35 S14 Steering Column Trim - $20 Switch Panel - $40 EXTERIOR S13 Hatch Rear Bumper (primer) $35 S13 Fastback Center Tail Light - $35 S13 Fastback Passenger Side Tail Light - $30 S13 Doors (local only) - $40 each S14 Zenki tail light center panel - $35 S14 Zenki Driver Side Tail Light - $30 MISC S13 Upper Radiator mounting brackets - $15 S13 Gas Tank Door - $15 S13 Steering column - $40 S14 Gas Tank (local only) - $100 S14 Steering Column - $40 (415) 724-0675 I have EVERYTHING so if you don't see it post/pm me. All stock parts are available. Shipping is also available on most parts. Last edited by DJPimpFlex; 05-21-2014 at 11:05 AM.. |
