![]() Join Date: Feb 2002
Enjuku Racing - ISIS Performance Engine Mounts - ** New Product **
ISIS Performance Adjustable Engine Mount Set - Nissan 240sx
http://www.enjukuracing.com/products...san-240sx.html ![]() ![]() http://www.enjukuracing.com/products...san-240sx.html ISIS Performance Adjustable Engine Mount Set are made of 2 poly-urethane bushings and come with 8 solid spacers to adjust motor height and to improve power to the rear wheels. These mounts are a essential upgrade to any swap or when replacing damaged factory mounts. Also, works with Hooker LS Swap mount brackets. ISIS Performance Transmission Mount - Nissan 240sx http://www.enjukuracing.com/products...san-240sx.html ![]() ![]() http://www.enjukuracing.com/products...san-240sx.html ISIS Performance Transmission Mounts are made of Poly-Urethane to help with transmission feel and to stiffen up the drive train to support better power transfer to the rear wheels. These mounts are a essential upgrade to any swap or when replaceing damaged factory mounts, they also pair great with our ISIS Performance Adjustable Engine Mount Set.
Office: 352-241-8399 / 1-888-SR20DET (772-0338) YouTube.com/c/EnjukuRacingParts http://www.enjukuracing.com [email protected] ![]() |
When i saw these i got really excited, i buy a alot of isis stuff, i support enjuku and their products and my car has never had a single issue with any of their products....with that said.Why they heck would you guys create another motor mount like this where there is a SINGLE bolt that goes straight through the mount to connect the chassis and motor together? it might as well be called a solid mount because this is going to create gobs of vibration. I was hoping you guys would make it with 2 offset studs to reduce vibration.I do like the idea of the included spacers, i think thats great...but please make a V2 mount that uses 2 offset isolated studs in the polyurethane molding process.just my 2 cents.
#3 | |
Instagram username:angelmkiv |
They make it because it's cheap chinese garbage that these idiots are buying. Just like 90% of products on the market these days
@UpshiftEngineering |
isis cheap chinese garbage has me making 280whp/340ftlb for a few YEARS now....
all i was pointing out is that this is clearly , in my opinion, a race only mounting system, a street setup should use a better form of isolation. how many isis products have you used? |
![]() Join Date: Nov 2004
Trader Rating: (53)
this is a slight spin on KTS engine mounts.... Circuit sports makes a copy of the KTS mounts as well, it looks just like this with 2 less spacers per mount. A lot of people have had trouble with these mounts breaking the bolt on the driver side, most likely from excessive clutch kicking
The poly bushing is 2" in height. Each shim is .25". Total height with all shims is 3".
These Isis Performance mounts utilize 12.9 grade bolts.
