05-30-2011, 10:08 PM | #1 |
A/C stopped working
I have a 92 coupe. AC has worked for the last two years but just recently it completely stopped. I think the compressor and everything is still good because it worked about a month ago.
When I push the A/C button, the little light doesn't turn on. And when I turn the defrosters on, it doesn't kick in either. Any ideas? fuse under the dash is good. |
05-31-2011, 08:42 AM | #2 |
check to see if you are getting power in and out of the control unit
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
05-31-2011, 08:40 PM | #3 |
Man w/ CTSV & a Car Seat
Check how much pressure/freon you have in the system. The AC compressor is designed to have a safety/pressure switch that prevents it from turning on if you dont have enough freon. You might have a leak somewhere and you dont have enough pressure in the system.
