12-16-2013, 11:58 AM | #1 |
ForcedFab Engine Mounts, Urethane Mounts $100.00 Shipped
ForcedFab LLC 240sx Urethane Engine mounts. ForcedFab Engine Mounts $100.00 Shipped We have a few of these sets left, We are going to offer a Christmas sale on them for $100.00 Shipped Use Coupon Code: FFXMAS. Once we are sold out we will be going back to our normal pricing. Order by Wednesday to get them in time for Christmas. The ForcedFab 240sx Engine mounts are designed to replace your worn out factory engine mounts.These mounts will eliminate the slop that your old stock mounts have and will keep the engine from rocking and slapping around in the engine bay. This will help improve power transfer from the engine to the ground and help reduce wear on your drive-line ForcedFab Engine Mounts are made in the USA using CNC laser cut steel and are professionally welded. We use high quality grade 8 fasteners. The Nuts we include are flanged to eliminate the need for washers, they also have nylon locking rings built into them to keep them from rattling loose over time. Our engine mounts use Energy Suspension Urethane Bushings and sleeves. We chose to use their bushings rather then molding our own to keep cost lower and the quality high. Energy Suspension has been manufacturing quality urethane bushings for decades so it just made sense to go with them.
http://www.forcedfabllc.com/ |
12-16-2013, 01:01 PM | #3 |
We tried to get them around the same height as stock, they are between 2.5" and 2.75" tall.
12-16-2013, 01:02 PM | #4 |
We can make them taller or a little shorter if you have a specific need.
12-16-2013, 05:09 PM | #6 |
It is a noticeable increase, but its still not as bad as completely solid mounts.
12-16-2013, 08:17 PM | #9 | |
these are setup more like every other bushing on your car. with the bolt through the bushing sleeve and the upper and lower parts of the mount isolated from each other via the urethane bushing. We use energy suspension bushings so we have no worries about the quality or consistency of them from set to set.
12-16-2013, 08:18 PM | #10 |
At this time we do not, We will be working on version of it soon.
Jon
12-17-2013, 11:10 AM | #12 |
It will likely be after the new year. The only S chassis's i have here now are setup for 1J, 1UZ, VH45. I don't have any thing here with a KA or Sr.
12-18-2013, 09:22 PM | #13 |
100$ ship to montreal , canada !!??
If so pm me , im in !!!
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
12-18-2013, 09:33 PM | #14 |
Canada Shipping would be $10.00 extra. I cant just give these away lol. The 10 bucks would make up the difference in my domestic shipping prices. PM me and i can send you a invoice for a set if you want to get them.
Thanks Jon
Tags |
forcedfab engine mounts, forcedfabllc.com |
