Old 10-15-2012, 11:46 AM   #31
headfirst427
headfirst427's Avatar
headfirst427 is an unknown quantity at this point
Right on, i knew pulling those studs would make it a lot easier, i was just under the assumption i could get the lower and upper intake out all at once, in one piece. I will get a stud puller and pop these guys off in the next day or so, thanks for the help!
1995 S14...1st Project
headfirst427 is offline   Reply With Quote
Old 10-15-2012, 06:41 PM   #32
hamizle
hamizle's Avatar
hamizle is an unknown quantity at this point
I just did this and I ended up having to cut the back one off.. good luck its a bitch
hamizle is offline   Reply With Quote
Old 10-15-2012, 10:08 PM   #33
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
You can, but it's 100x easier to just take them apart and reassemble them later.
I doublenutted all 4 of my studs and replaced them with bolts from a spare manifold.
Tips:
1. Put on first nut. Tighten down all the way pretty tight.
2. Put on second nut. Tighten down as much as possible with the socket only on the second nut.
3. TIGHTEN the nuts at the same time with a long socket, until you hear the stud crack loose. It might help to tighten-loosen tighten-loosen until it cracks.
4. Use an open wrench on the first nut (the inside one) and loosen. The stud should spin.
If you get the stud off, and the nuts are stuck together on it, either find new nuts or have fun .
Frank_Jaeger is offline   Reply With Quote
Old 10-16-2012, 12:18 PM   #34
240sxfan6882
240sxfan6882's Avatar
240sxfan6882 is an unknown quantity at this point
Tips:
I also did this "double nut" method. Look for it on youtube, there is a video there of someone showing you how to. It was surprisingly easy to pull them out that way.
240sxfan6882 is offline   Reply With Quote
intake, ka24de, removal, s13
