Old 06-13-2005, 06:15 PM   #1
Xren17
Xren17 is an unknown quantity at this point
Need A S14 Driver Side Rear Caliper
I went to change my rear brakes and the driverside rear piston wouldn't turn back into the housing. Does anyone have one laying around in socal? I know I'm doing it right since the passenger side went in fine.
Thanks.
-Ren
Xren17 is offline   Reply With Quote
Old 06-13-2005, 06:20 PM   #2
sw20>>s14
sw20>>s14's Avatar
sw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond reputesw20>>s14 has a reputation beyond repute
Send a message via AIM to sw20>>s14
no one cares unless if theyre in the wtb section...are you twisting and using a c-clamp? i find that it make the job a whole lot easier...
sw20>>s14 is offline   Reply With Quote
Old 06-13-2005, 06:24 PM   #3
Xren17
I haven't tried the c-clamp combo. I'll give that a try.
Old 06-13-2005, 06:30 PM   #4
Ritz S14
Ritz S14's Avatar
Ritz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud of
C clamp wont do you squat on a rotating piston.
You'll have to turn the piston clockwise with a big ass flat head, needle nose pliers, or you can always use the correct tool.
Ritz S14 is offline   Reply With Quote
Old 06-13-2005, 06:34 PM   #5
Xren17
Like I said, the passenger went in fine. The driver side turns also but it just won't go back into the housing.
Old 06-13-2005, 06:40 PM   #6
Ritz S14
Ritz S14's Avatar
I don't think there is anything wrong with the caliper since it doesn't seem to be fronzen. Try turning it in the opposite direction?
I guess the clamp would be of use in this situation. Just that I never had to use one.
Old 06-13-2005, 07:31 PM   #7
Xren17
It went in after some persuasion with a hammer but somehow the hole where the bolt thread into is strip. This is not my day. Hopefully I can just retap it. If that doesn't work it's back to replacing the caliper.
-Ren
