Old 04-11-2014, 11:45 PM   #1
Derek232
Derek232 is an unknown quantity at this point
Want to run e-85 on an sr20
I want to go to e-85 with my sr20 it's a built motor with a t28 turbo, I've got a walbro 255 fuel pump but I don't know what size injectors will be best for running e-85. I've got an apexi neo safc to tune. Any suggestions on injector size. I'm also planning to go to a 30r charger and looking to make 450 to 500. Will I need bigger injectors with that setup?
Derek232 is offline   Reply With Quote
Old 04-11-2014, 11:50 PM   #2
Dboyizmlg
Dboyizmlg's Avatar
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Did you search first?
There are a few threads on this.
Dboyizmlg is online now   Reply With Quote
Old 04-11-2014, 11:53 PM   #3
Dboyizmlg
Dboyizmlg's Avatar
Just to enlighten you a bit, E85 is best ran with a better management ecu.
Like the APEX'i PFC, AEM, or HALTECH.
If you are planing on using a gt30 series turbo you will need 1,000cc injectors or higher.
Old 04-12-2014, 12:24 AM   #4
Derek232
Sorry, I should've looked harder. But for now I'm just sticking with my t28. I've been looking into getting AEM. Thanks for the info though
Old 04-12-2014, 12:35 AM   #5
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Honestly if you plan to upgrade your turbo later on go bigger on injectors. For my stock rb on e85 I went straight to 1000cc. Id go with 1000 and aem and you'll be set. Then if you plan to throw a bigger turbo on all you need is a retune.
smoked240 is offline   Reply With Quote
Old 04-12-2014, 08:00 AM   #6
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
Take a look at the NismoTronicSA Tuning System before you make your ECU decision. It includes flex fuel support with the addition of an Ethanol Content Analyzer.
OnTheChip is offline   Reply With Quote
