06-01-2013, 08:39 PM | #243 |
First Dyno. Seem right?
07-12-2013, 08:13 AM | #244 |
350++ hp
im building a 93 ka24de from the bottom up. i'm shooting for an hp range of 350 - 400. i've got eagle rods, wilco pistons with a .20 over bore, bc stage 2 cams, bc valves, bc valve springs & retainers, excessice fuel rail, excessive cast intake, excessive SR oil pan. what size turbo should i be looking for along with injectors and fuel pump?
07-12-2013, 09:24 AM | #245 | |
And id also like to just like to say you should consider getting rid of the bc cams for kelford stage 3 instead.... you wont be disappointed. |
09-25-2013, 08:58 AM | #250 |
Pre tune new KA24DET question.
Still kind of new here hope right thread.
Just finished putting a new KA24DET in a 89 240sx. I have the boost set at zero and the waste gate open and still the stock injectors ( 600cc are ready when motor is broken in and boost is set and heading to tune shop ). My question... The motor has a very rough idle and when I approach a stop the motor stalls. Less than 1 hr and 15 Km on the motor and not over 3000 rpm yet. Does the ECU need to be set up differently? The timing is set to stock specs and not sure what else to do. Thanks for any help. |
10-17-2013, 01:06 PM | #251 |
Valve cover compatibility?
Want to do some work on a ka24de valve cover (polish, paint, w.e.). Do any other vehices with KA's have the same valve cover as a 97 240sx? Of course I cant an s14 at pick and pull but thought I could potentially find a cover for the same engine! I know s13 ones are different, but I was thinking SUV's and shit....
10-30-2013, 11:43 AM | #252 |
how much power can a stock Exedy Clutch hold?
I think I'm making about ~210WHP/TQ and about ~240HP/TQ at the crank Max HP and TQ numbers were about the same I'm planning to replace the clutch with a Bran new OEM Exedy but not sure if I should be upgrading
11-06-2013, 08:33 AM | #253 | |
You need to upgrade to at least a Stage 2. The stock clutch will slip under any boost. I have a spec stage 2 in my car and I love it. Pedal feel is great.
"I have no cupholder" |
11-14-2013, 06:25 AM | #255 |
As far as main bearings go, should I just take the numbers off the block and the crank and order OEM with the varying grades? Or would I be better off getting ACL or Clevites and just plastigaging them to assure oil clearance is within spec?
12-14-2013, 01:35 PM | #256 | |
You retain a stock like idle. and they are good for 400 WHP + ... I need them. |
12-17-2013, 10:20 AM | #257 |
Kelford cams are the best I've run. I ran Kelford 272s in my 600HP EVO. Lumpy idle can be tuned out some for ease of DD. I personally loved the lope and it did not affect my DD ability.
01-04-2014, 04:50 PM | #258 |
ka or sr
hey every i have save up about 1500 and i know i could get an sr but im not sure if i should build the ka im looking for the less expensive and less problemactic build
01-16-2014, 10:18 AM | #259 |
couple questions for you awesome people. z31 turbo? hard to make work? i know its a t3 but ive read some are water-cooled etc and the elbow on it 6bolt(i think)? anyone make downpipe specifically for this? will a external waste gate be needed or what? (had the turbo for a day cause he was moving and never got to check) basically, what would what would be needed to make this work as i can get a pretty much mint one for free? this is my first plan that im leaning towards as the turbo is free. also. if im shooting for 275whp is a stock motor okay? up to how much hp? also. my next plan would be a t25 with normal: 370 injectors, fmic, z32 maf, enthalpy tuned ecu (for both setups actually) yada yada yall know the drill. but heres my next question. if i, for example, use an isis sr20 elbow will the isis sr20 downpipe fit the chassis well even if it is a ka? of course id upgrade the clutch and put in a high flow cat if not a test pipe. glad i found this sticky since tax return season is around the corner. thanks in advance fellas.
05-04-2014, 08:53 PM | #261 | |
He said it pretty much became 94-96 octane. TUNING is a must though if you decide to blend the two.
06-08-2014, 03:55 PM | #262 |
so guys yesterday driving my car can it started like the car didnt have enough power to turn the drive shaft its made like a rattling type noise car has an oil leak "bad' but I keep oil in it car rattled and lost power till it died out sounded like battery had lost charge when I tried to start it back up got started but further down the road total y died no lights come on no nothing just rattled the whole time just before im about to tear it apart just want some ideas on what migh have happened
10-15-2014, 03:46 PM | #263 |
hey guys,
So I've been searching for more information, but have had no luck. Can anyone verify/deny the necessity for re-gapping spark plugs for winter vs. summer in SoCal? Thanks. |
01-26-2015, 01:29 AM | #264 |
Hey everyone new to the forum. A year ago I walked into a awesome trade for a built 95 240 with the ka-t set up. Has been great to me up until a couple weeks ago. I had gotten into the throttle hard in third gear when the car started to stutter. It would do it with anything over half throttle, by the time I made it home it was missing at idle and sound very similar to a sti ( much to my dislike). Any ideas of possible causes or remedies?
01-26-2015, 04:43 PM | #265 | |
MAF Ignition system
MRP Manufacturing |
01-26-2015, 05:13 PM | #266 |
Thanks for the tips kat per. I called the nearest speed shop. And they all but confirmed my suspicions of it being a fault aem pencil coil. Two were replaced by previous owner.
04-10-2015, 02:10 PM | #268 |
We have you covered for your S13 with a KA, either just an engine harness or a "combo" which is the engine and transmission harness together. http://www.wiringspecialties.com/ka24des13.html
Visit our Website - Check out our Blog - Like us on Facebook - Follow us on Instagram |
