Old 12-22-2015, 02:50 PM   #1
WORKS15
WORKS15 is an unknown quantity at this point
GTX3067R or GTX3071R
Hi,
I have a S15 Silvia (im from New Zealand) and im thinking about changing my turbo as i hate the amount of lag it has, its just not enjoyable on the street at all.
Current setup is:
HKS 1.2mm head gasket
ARP head studs
Kelford valve springs and retainers
Kelford 266/270 duration, 11mm/11mm lift
Sard 850 injectors
Walbro 500hp fuel pump
Tomei FPR
RaceFab T3 top mount manifold
Garrett GT3082R .83
Turbosmart 38mm wastegate
Front mount intercooler
3" down pipe
3" exhaust with 1 resonator and 1 rear muffler
Power FC
Currently makes 306kw @ 20psi at the wheels on BP98 octane fuel.
Im not getting full boost untill about 5000RPM!!
I basically want the most responsive T3 turbo that will still make around 300kw or less and come on boost at 4000RPM or under. Main reason why i want to stick to T3 is so i dont have to change my manifold and modify everything.
So the two options i thought would be suitable is a Garrett GTX3067r .63 or a GTX3071R .63 ........maybe even a GT3071R .63.
The GTX3067r is really appealing to me but i just cant find any data on the web for people who have used them on a SR20DET.
All opinions and feedback are welcome.
Thanks
WORKS15 is offline   Reply With Quote
Old 01-02-2016, 12:56 PM   #2
Asil
Asil is an unknown quantity at this point
Although it is not a T3 one, I personally used this on my SR20 and it performs just like what you are looking for (no lag).
http://www.atpturbo.com/mm5/merchant...egory_Code=TBO
Asil is offline   Reply With Quote
Old 01-02-2016, 02:44 PM   #3
NiSilS14
NiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond reputeNiSilS14 has a reputation beyond repute
gtx2867 or gtx3071, naturally the smaller the turbo the more responsive it is at the expense of top end power. 3067 isn't worthwhile imo, as it's just a 2867 with gt30 hotside, gains would be marginal over a 2867. It's also worth looking at twin scroll housings as it would allow better top end while retaining good spool characteristics, but it would require a new manifold if you're not already set up for twin scroll.
NiSilS14 is offline   Reply With Quote
