Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 01-31-2012, 02:48 PM   #1
TypeXFan
TypeXFan is an unknown quantity at this point
s13 Just want to clarify the Z32 5 speed Transmission
I saw a NA Z32 5 Speed tranny at the junkyard that im considering pulling. I did a little research and to my understanding both the NA and TT Z32 5 speed transmissions (RS5R30A) are the same. Can anyone confirm or deny this for me before I go pull it from the junkyard?
TypeXFan is offline   Reply With Quote
Old 01-31-2012, 03:17 PM   #2
AW11ERIC
AW11ERIC is an unknown quantity at this point
Not quite the same due to the TT flywheel being larger. You have to grind off about 1-2mm (from the bellhousing) to get it to clear. Not a huge deal but for simplicity's sake it's easier to find a TT transmission.
AW11ERIC is offline   Reply With Quote
Old 01-31-2012, 07:09 PM   #3
niscur29
Location: Back IN FL, bring nice cars to the fail state!
niscur29 is an unknown quantity at this point
^Yup...
Just got done putting an NA tranny onto my VH using a TT flywheel/clutch. Had to hand file the starter area and the bottom of the inside of the bell housing. The starter area/hole was the major filing. The NA bellshousing has like little knobs on the inside and there was just a little bit of interference that I filed them all flat.
niscur29 is offline   Reply With Quote
Old 02-05-2012, 02:46 PM   #4
troyp47000
troyp47000's Avatar
troyp47000 is an unknown quantity at this point
+1. I saw them side by side. The tt ones bell is a little bigger.
boats and ho's
troyp47000 is offline   Reply With Quote
Old 02-09-2012, 09:33 PM   #5
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
3rd line down...
FAQ Page - Mazworx - Home of the World's Most Powerful SR20s. From engine work to chassis to even full turn-key racecars, we can do it. Even though we specialize in Drag Racing Nissans and the SR20, our capabilities are broad.
My SR20VET
Old 02-23-2012, 10:55 PM   #6
JeeBus
JeeBus's Avatar
JeeBus is an unknown quantity at this point
B/s
The bell housings are different by inner diameter.
The 90-96 trannies all had the same syncros, it wasn't until '98 that Nissan updated the syncros on them.
JeeBus is offline   Reply With Quote
