front wheel problems
after getting an alignment with everything at factory specs, my driver side wheel is closer to the front of the fender and the passenger side wheel is closer towards the door. i didnt hit or drive over anything before, it was like this when i bought the car. i have aftermaket tension rods and adjusted the caster to spec, but still the wheels are like this. i was starting to think the rack maybe out or something could be bent. i check the control arms but they look pretty straight, but i do not know if the old owner hit anything. the rad. support does look rough tho, like where the headlights go and the headlights do not line up with the bumper and hood. any other things to look at?
![]() Join Date: Oct 2007
1. did alignment guy mention anything? because its supposed to be straight AFTER you leave. most places wont work on a car that can't be straightened out or has damage to parts.
2. post pics of said problems. 3. look at the alignment sheet that they gave you. |
#6 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
i'd bring it back and tell them to at least check it again and that you think your caster is off
Slip Gypsies Blog Quote:
![]() Join Date: Nov 2004
You can't always see a lca. FYI.
Also, if your stock tension rods are blown, your wheel will be moving fore and aft. Thus changing your caster.
![]() Join Date: Dec 2002
Caster is not adjustable in the front with the OE parts. Worn tension rod bushings will change the caster, as well as worn LCA bushings or a bent LCA. If all of your OE parts are solid and not damaged, the core support has been moved back from a low impact. Adjustable tension rods are the easiest solution unless you pull and replace the core support.
