Old 01-22-2012, 01:16 AM   #1
eli-s13
eli-s13's Avatar
eli-s13 is an unknown quantity at this point
SR20det Circuit Sport Turbo Line HELP!!!
Ok heres my dilemma, I'm installing the circuit sport turbo lines on my s13 sr20 with a stock t25 and i need some help on the oil line.
[IMG][/IMG]
The fitting wont sit flat against the turbo here and by looking at it, it appears that it wont because it ground out before it can seal. Was thinking of switching the line around and putting the banjo bolt into the turbo instead of the block but im just not sure on what to do. Any help would be greatly a appreciated.
eli-s13 is offline   Reply With Quote
Old 01-22-2012, 07:56 AM   #2
eli-s13
eli-s13's Avatar
any one have an idea?
Old 01-22-2012, 08:37 AM   #3
Sileighty_85
Sileighty_85's Avatar
The oil fitting doesnt use a Crush washer.
If you looking inside you will see that the fitting and turbo are tapered. Much like how -AN fittings work.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
