T28 Boost Issue (yes, I have searched!)
A mate and I have just finished fitting a T28 to my S13, got it running, set the Profec A at 1.0bar took it for a drive but both controller and mechanical gauge still read 0.7bar? I've checked for boost leaks and made sure all the pipes are tight. The turbo also came with a adjustable Forge actuator, but surely it won't make a difference if I'm running the Profec??
Just to add, I have the correct mods to support (STG2 chip, walbro, filter etc). Thanks for your help. |
![]() Join Date: Dec 2006
Do you have injectors? the 370cc max out after 10-11psi and will lean out after 5500rpms
so running 14psi is not a wise choice until you upgrade the injectors. yes the adustable actuator will make a differnce loosen for less tighten for more
![]() 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
![]() Join Date: Apr 2005
ive never used a profec so i cant say for sure, but how do you know its at 1 bar? does it have auto boost setting? try upping the gain, you should see more boost
#4 | |
had another friend we kept his SR T25 at 18psi for well over a year on stock injectors
If you have a H-Dev Stg2 chip then you need to keep the stock injectors and keep the boost at 1bar.
The actuator shouldn't make a difference because the controller should keep the wastegate closed/flapping until your boost setting is reached... Are you sure the controller has a good boost reference? Also considering that you're in England i'm guessing you have a ca18det...
S14 240SX aka "The Dirty S14" fizzerkart.com/s14.html |
#6 | |
Here my Dyno sheet Fully rebuilt/ built SR, I was running T28 .8bar Stock ECU, MAF, Injectors, Cams,
Make sure the dip switches on the prfec are correctly set. They might be set for if overboosting occurs and aren't letting it boost enough.
GReddy Profec |
