10-07-2016, 09:11 AM | #6 | |
Thanks! |
10-18-2016, 09:12 AM | #7 |
Bump and update, I took the motor out for some major maintenance
New as of 10/18/16 Turbo gaskets, intake manifold gaskets, o rings, headers gasket, oil housing gasket, oil filter oem, new front main seal and rear, new main pulley bolt, new oem thermostat and o ring gasket, new caps/block offs, new oil, new slump and oil pan toyota oem FIPG made gasket, new headers OEM studs, bolts, washers properly done, new lines, fittings, used ARP thread sealer on everything threaded, cleaned/scrubbed the block to MINTY, new valve cover gaskets, new spark plugs, lots of new other shit. Here are some shots I took Also those ugly FMIC pipes will not be teal anymore haha ill be doing it silver or some kind of grey. Next I will be laying out heat reflecting mat in the transmission well and other areas. |
10-19-2016, 06:29 AM | #12 | |
No thank you I dont really want to pick up payments or add cash for that car its not a car I see myself in unfortunately |
10-26-2016, 07:51 AM | #17 |
10-26-2016, 01:59 PM | #21 |
I just checked http://postimage.org/ again and it seems i had to add it to my exceptions to be able to see the photos, photos work fine for me now
