Old 07-30-2008, 01:16 AM   #1
Cobbs
Cobbs is not welcome here anymoreCobbs is not welcome here anymoreCobbs is not welcome here anymoreCobbs is not welcome here anymoreCobbs is not welcome here anymoreCobbs is not welcome here anymoreCobbs is not welcome here anymoreCobbs is not welcome here anymoreCobbs is not welcome here anymoreCobbs is not welcome here anymoreCobbs is not welcome here anymore
4th cylinder misfiring ( ka24de )
I have everything except a spark to my 4th cylinder.
I bought a new distributor/spark plug wires/spark plugs and still nothing.
I scanned my obd and it came up with P03040.
got any suggestions on what I should do?
Cobbs is offline   Reply With Quote
Old 07-30-2008, 03:34 PM   #2
slidewaysmn
slidewaysmn's Avatar
slidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really nice
You sure its not a vacuum problem? faulty injector? If you are sure its spark, yet you replaced the plugs, plug wires and distributor...i would try replacing the injector...common problemo...and what is the or could be a wiring short... anyone else? ha
'95 Zenki
'85 Cressida
slidewaysmn is offline   Reply With Quote
Old 07-30-2008, 06:19 PM   #3
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
test your injector. and test for noid signal
Dave
RB25 280z GT30/76R 441hp/381tq [email protected]
Z U L8R is offline   Reply With Quote
Old 07-30-2008, 06:27 PM   #4
turns101
turns101's Avatar
turns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond reputeturns101 has a reputation beyond repute
Send a message via AIM to turns101
so you dont see any spark when you have the wire in the plug on the head and start the car?
OR
You just know you have a #4 misfire?
-Jeff Abbott. Big white guy, little green car. late spooler
turns101 is offline   Reply With Quote
Old 07-30-2008, 06:52 PM   #5
memo92
memo92's Avatar
memo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfectionmemo92 is close to perfection
Dave
I agree, check that#4 cylinder injector. Might be cloged, so replace it w/ a new one. GL
memo92 is offline   Reply With Quote
Old 07-30-2008, 07:10 PM   #6
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
wait, you got a whole new distributor?
or just a cap and rotor?
clark is offline   Reply With Quote
Old 07-30-2008, 11:25 PM   #7
Jonnyblaze
Jonnyblaze's Avatar
Jonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymore
i had the same problem.. my injector was bad.. grab a multimeter and test it
'91 Hatch - Work in Progress
Jonnyblaze is offline   Reply With Quote
Old 07-31-2008, 01:31 AM   #8
Cobbs
thanks for the feedback, Ill check my injectors tomorrow.
Old 07-31-2008, 09:20 AM   #9
turns101
turns101's Avatar
Was skipped over here because I have a MIata LOL!!
You said you dont have spark!! You can have a good injector or bad injector and with no spark it doesnt matter.
So what are we checking injectors for if there is no spark?
So is there no spark or simply a mis fire??
Old 07-31-2008, 12:06 PM   #10
Jonnyblaze
Jonnyblaze's Avatar
whoever gave me neg reg for thinking i dont know how to test the injector can go fuck themselves
Old 07-31-2008, 04:12 PM   #11
Cobbs
well, I know the cylinder misfire can be alot of things. and as of right now Im trying to narrow it down.
Once I get paid, Ill buy some new spark plugs because I fouled mine up.
Ill clean out the injectors, replace any worn vac lines, check the maf, put in the new plugs, swap out a new fuel filter then try to fire her up.
Old 07-10-2009, 02:58 AM   #12
jaja
jaja is making a name for him/her selfjaja is making a name for him/her self
Send a message via AIM to jaja
just realized that cobbs was banned.... maybe someone else can help me... (93 KADE)
i think i have the same problem.... cobbs - what ended up being the problem? i did the remove the injector connecter test, and found the #4 (closest one to the firewall?) and no change in that one.... (rest were fine - had some change), thus i'm thinking its the injector.
but i just removed the plug in that one and it was pretty pretty dark/black. wondering if it has spark. driving to the auto store to get a new one... maybe that may solve my problem
I also hear this 'hissing' sound near the charcoal canister.... that normal? i think its a vacuum leak, but cant seem to find one... should i just spray the lines with bubbly water?
93 S13 Vert: KA, 5 Spd, intake, exhaust, coilovers, etc
94 bronco: 6"+35"
jaja is offline   Reply With Quote
Old 07-11-2009, 04:15 AM   #13
jaja
wasn't the spark plug.... tried to pull out the injector, ended up in the ER.. no joke. turning out to be a really expensive 'fix'
94 bronco: 6"+35"
